06-17-2018
22:38
18:54
06-17-2018
22:38
18:54
Fitbit Charge 2 display not turning on even when button is pressed. I’ve had it for over a year now (this is my third Fitbit and I had 2 Fitbit Charge HR before this one). It did it last week and I plugged it in the charger and reset it and it worked after that but did it again yesterday and when I did charger + reset, it lit up but right away would not turn on again after the display turned itself off and still today nothing I try turns it on. It works fine and picks up all the usual info as far as I can tell. When you hit the button, you can feel the vibration (without seeing the display I must be turning my notifications on and off) and the batterie is full to high level.
Can something be done or is it now defective and time to buy a Fitbit Versa?
06-18-2018 04:59
06-18-2018 04:59
It's nice to see you around @CPK-Chantal! Thanks for taking the time to troubleshoot this inconvenience with your Charge 2's display. Nice way to go!
Since this sounds a bit more serious, I've created a Support Case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know.
06-18-2018 07:07
06-18-2018 07:07
Mine is doing the same thing!
Need help!
Best Answer06-18-2018 07:12
06-18-2018 07:12
Thanks for stopping by. Welcome here @STSJAX! Have you tried charging your tracker for 2 hours or so? Whenever you connect your tracker, do you see something on the screen? Are the green lights on the back still flashing? Do you feel a vibration?
Please try restarting your Fitbit by following these steps:
Looking forward to your response!
Best Answer06-18-2018 07:41
06-18-2018 07:41
06-18-2018 08:31
06-18-2018 08:31
Thanks for the details provided @STSJAX! If your tracker is syncing, what about the restart? Did you try performing it? Please follow the steps I've shared above and let me know if something changes.
I'll be here, so tag me anytime!
Best Answer06-18-2018 09:37
06-18-2018 09:37
Thank you so much MarreFitbit for your quick, helpful response to my FITBIT problem and for creating a Support Case on my behalf. You made my day even if I don't get a fix. At this point would even settle for a confirmation that it is not going to be a small fix and/or something that would help confirm that theory or disprove it. I understand it is tech and all my 3 Fitbit so far have all been well worn and used through out the years. They are not at a cheap price (especially since my next one will be a VERSA or IONIC) but I value them in my fitness journey. I only wish they would all come with a DONGLE like my two FITBIT CHARGE HR did. If I did not have those 2 dongles when I got my CHARGE 2 I would not have been able to sync it and when both dongles totally fell apart and I was still unable to connect and sync without a dongle I landed up buying a FITBIT ZIP on a clearance sale at a nearby store for 39.99$ for the only purpose to get the dongle in the box. (I did not think I would have the time to order one online and still get it on time before losing some data since it took almost a week of trying different things to try to get it to sync without a dongle). My first Fitbit Charge HR, the casing totally fell apart. The second one, the band kept falling of and after crazy gluing the band on some of the glue went on the front casing but still works but does not look “pretty”. My present FITBIT CHARGE 2 has also band falling off problems which I’m hoping my next choice(s) does not.
Thanks again and have yourself a great day and week MarreFitbit.
Best Answer06-18-2018 10:11
06-18-2018 10:11
My pleasure @CPK-Chantal! Thank you for the thorough feedback for the Fitbit devices. This has not gone unnoticed and be sure that I will pass this along.
We don't want to create frustration in our customers. Fitbit has been designed to provide motivation and help you to reach your daily goals to success. Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on that feedback.
Please know that the Support Team is doing everything possible to efficiently work through a backlog of inquiries, providing each customer with helpful, personalized assistance.
Tag me anytime if you need further assistance! ![]()
Best Answer06-18-2018 18:17
06-18-2018 18:17
New Charge 2purchased for Fathers. Day gift for my son, an engineer.
Best Answer06-19-2018 08:07 - edited 06-19-2018 08:07
Welcome to the Fitbit Family @furnreptoo! I'm happy to hear about your Father's Day gift.
So nice of your son!
Are you having issues with your new Charge 2? Is the display not working properly?
Best Answer06-19-2018 12:11
06-19-2018 12:11
Interestingly my mums Charge 2 is doing this exact thing except it's completely dead even though it has a charge in it. I've tried plugging it into the mains and into a USB port and tried resetting it but there is no vibration when it's plugged in or a reset is attempted. One thing I did notice is that the time was incorrect on it and it would fail to obtain a heart rate shortly before dying completely.
06-19-2018 12:56
06-19-2018 12:56
Best Answer10-29-2018 14:17
10-29-2018 14:17
I am having to be same problem. The screen won’t come on but I feel the vibration and see the green lights on back as well. I have tried charging it overnight as well as restarting it using then directions on here.
Best Answer08-22-2019 20:56
08-22-2019 20:56
I have the exact same issue. It's the Fitbit display will not come on, however when I hold the button down it does vibrate and also it is sinking the normal data to the Fitbit app. However no display
09-20-2020 10:13
09-20-2020 10:13
Any solutions? Mine is doing the same thing.
Best Answer09-20-2020 19:11
09-20-2020 19:11
I have attempted the restart also, following instructions provided to others on this topic. Like the others, my fitbit is gathering data, but I have to use the phone app to see the data. The screen is very very faint- cannot really read it (which makes it useless as a watch!). Please help!
Thanks
Lisa
Best Answer06-12-2021 06:20
06-12-2021 06:20
I'm also dealing with the same thing. I reset it already, and nothing still works. The 'ghost' button seems to like going through the different things on the Fitbit but that's all it does. It also turns on and off notifications, tries running, and does the relax option multiple times
Best Answer06-12-2021 06:36 - edited 06-12-2021 06:37
I am not sure if mine is the same issue or not. My display disappeared so I charged it. Nothing but some buzzes. So I charged it overnight. Nothing but some buzzes. It has been charging for 2 days now and on my phone it still says my battery is dead and when I hold the button for a long while I will get nothing but a series of buzzes.
Please help.
@@Marrefitbit
Best Answer06-13-2021 14:51
06-13-2021 14:51
This is also happening with my charge 2. The display is not working, it’s still vibrates and data is being recorded in the app but I can’t see anything on the screen. I have followed the reset instructions a couple of times, the first time the screen worked, albeit there was nothing legible and the subsequent times, it vibrated but nothing was showing on screen. It’s also no longer holding charge very long.
any suggestions?
Best Answer06-13-2021 15:08
06-13-2021 15:08
Please help.
@@Marrefitbit
