07-01-2019
11:20
10:18
AlvaroFitbit
07-01-2019
11:20
10:18
AlvaroFitbit
Hello,
My charge 2 hr was showing a black screen for a few hours so I plugged it in to charge. As soon as I pugged it in, the fitbit home screen and model number came up and then it showed the charging bar as normal. I thought it was fine and when I went to check on it after about an hour of charging, it was frozen on the battery screen and the bar hadn't moved at all to show that it was charging. I tried to hold the button for 10-12 seconds to reset it and it will vibrate but all it shows is the battery screen. I also tried to unpair it from my phone to see if that would do anything but it didn't. Does anyone know how to fix this?
Thank you
07-01-2019 13:02
07-01-2019 13:02
Update: the screen is just completely black now and no longer frozen on that battery screen. It will still vibrate when I push the button and will still sync to my phone but they display is no longer working.
07-01-2019 20:12
07-01-2019 20:12
Try resetting the Charge 2 with the charger connected. Depress the left button until the Fitbit symbol is displayed. And attempt to pair with the app on the phone.
07-01-2019 22:38
07-01-2019 22:38
My charge 2 screen has also gone blank this morning / when I check through the app it says battery is full.
Any help will be appreciated
07-01-2019 22:43
07-01-2019 22:43
