02-13-2019
03:23
17:14
02-13-2019
03:23
17:14
Plz tell me sir how to reset and connect again
02-14-2019 10:39
02-14-2019 10:39
@Vipinjaat Welcome to the Fitbit Community! It's great to have you here! Sorry to hear that your tracker isn't syncing. Which phone are you using? Is it compatible? You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Let me know how it goes!
