07-19-2019
12:38
14:41
07-19-2019
12:38
14:41
My Fitbit loses its charge after 2 hours the past 3 days
07-20-2019
10:20
09:09
07-20-2019
10:20
09:09
@Pawillia, welcome! It's good that the community is growing!
Let me help you with your Charge 2 battery life. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
07-22-2019 18:05
07-22-2019 18:05
07-22-2019 23:44
07-22-2019 23:44
My Charge 2 is doing the same! I have tried all the troubleshooting tips but everytime I charge it, it turns off again after about 5-10 minutes! I think there may be a slight crack accross the HR sensor but I had no problems with that working, it just won't hold power.
