08-03-2021
08:14
11:43
AndreaFitbit
08-03-2021
08:14
11:43
AndreaFitbit
I have no idea what has happened, but my Fitbit seems to have a mind of its own, I can’t turn it on or check my stats or notifications, but if I do press the ‘on/off’ button on the side, it will still make a vibration sometimes, other times it will turn on by itself and start vibrating randomly. It also keeps scrolling up and down for me and even changes my quick settings. I’ve tried all the steps about charging it and holding it for 15 seconds etc. But it still won’t work. I’ve never swam in it, it’s never got anything stuck in it. It just decided not to work. I’ve had my Fitbit for over a year and I’ve never experienced anything such as it. Please tell me someone else has experienced this and if so how do you fix it? Thanks 🙂
08-03-2021 08:24
08-03-2021 08:24
Hi @Jamierowles11 which device do you have?
08-03-2021 08:30
08-03-2021 08:30
Hi Odyssey13, I have the Fitbit charge 3
Best Answer08-03-2021 08:40
08-03-2021 08:40
I'll put your post into the Charge 3 area to get the best possible response.
08-03-2021 08:42
08-03-2021 08:42
If you have an issue with your Charge 3 screen try restarting your device. If the issue persists, please contact Customer Support.
08-03-2021 09:00
08-03-2021 09:00
Thanks for the advice, my Fitbits display now works, but the main problem is still there, it’s still controlling itself. The situation is hard to explain but it seems to have a mind of its own and randomly swipes up and presses random notifications or changes my settings in quick settings, and does all this without me even touching the Fitbit, I’m genuinely completely confused with what to do.
Best Answer08-03-2021 11:28
08-03-2021 11:28
@Jamierowles11 I've asked a moderator to stop by to assist you with this. They might know just what to do.
Best Answer08-03-2021 11:47 - edited 08-03-2021 11:49
Welcome to the Fitbit Community, @Jamierowles11. Thanks for letting us know about the steps you have performed in order to make your Charge 3 work.
I have seen a couple posts with what you have described and I understand how frustrating this could be. The best way to get help for this problem is to chat with us online or give us a call. Clickhereto get connected.
Thanks for the heads up and your assistance @Odyssey13.
Keep on visiting the forums.
