10-17-2018
03:59
15:06
10-17-2018
03:59
15:06
Hello, today, my Fitbit Charge 3, which was perfectly running for a week, was frozen. Restart first didn‘t work. Black screen, nothing happened. It did not show the charging symbol. Then I connected it to my MacBook. Suddenly it woke up. So what will happen when I don‘t have a MacBook to wake up my Chaarge 3?
By the way, this happened 1 day after I installed the new firmware. A bug?
02-05-2019 12:41
02-05-2019 12:41
Your solution worked. but only after 5 attempts. Can you explain why this happens? Thanks!
Best Answer02-05-2019 13:28
02-05-2019 13:28
Best Answer02-08-2019 00:25
02-08-2019 00:25
Fit bit charge 3 has frozen nothing appears on the watch face
Best Answer02-08-2019 04:32
02-08-2019 04:32
02-10-2019 07:05
02-10-2019 07:05
Thank you that worked
Best Answer02-14-2019 05:57
02-14-2019 05:57
My charge 3 will not show my steps or anything
Best Answer02-14-2019 06:57
02-14-2019 06:57
Pressing and holding for awhile didn’t work. Any other ideas?
Best Answer02-14-2019 08:45
02-14-2019 08:45
Best Answer02-14-2019 08:56
02-14-2019 08:56
Best Answer02-14-2019 09:01
02-14-2019 09:01
Best Answer02-14-2019 09:20
02-14-2019 09:20
Sadly it seems to be only by chance that holding the button will reset the unit. The 8 second or even 15 second hold may or may not reset the unit. Experience shows the holding for long periods and doing this multiple times may work.
If if that does not work set the unit aside, get a good nights rest and try again in the morning. You may be lucky!
Clearly there is no positive way to get a charge 3 back to life. Sad but true!
Good luck!
02-14-2019 09:24
02-14-2019 09:24
Best Answer02-18-2019 04:16
02-18-2019 04:16
good morning, my fitbit was just frozen for a few hours and doing what you suggested worked. Thank you. Can you say what may have caused the fitbit to freeze?
Best Answer02-18-2019 09:04
02-18-2019 09:04
02-18-2019 09:52
02-18-2019 09:52
This freezing problem is a real pain. I suspect that it is a problem with the internal software. I have never seen any Fitbit reaction to this.
I also find find that syncing with an iPhone or iPad is slow and erratic. Mine will never stay on all day syncing. I need to reconnect to my phone or iPad on a frequent basis.
Really the fitbit charge 3 is not reliable. Unfortunate but true!
02-18-2019 10:18
02-18-2019 10:18
Best Answer02-25-2019 08:27
02-25-2019 08:27
Thanks it worked, but why is this happening in first place? Hope it will not happen again.😅
Best Answer02-25-2019 08:28
02-25-2019 08:28
It will work, just conect to charger it vibrates but no battery appears.. still u press side button for 8 sec it wrksw
02-25-2019 08:28
Best Answer03-23-2019 08:56
03-23-2019 08:56
My froze this morning. Correct date and time, but nothing else. Followed the directions to plug into charger and hold down button. It worked. Thanks.
