10-17-2018
03:59
15:06
10-17-2018
03:59
15:06
Hello, today, my Fitbit Charge 3, which was perfectly running for a week, was frozen. Restart first didn‘t work. Black screen, nothing happened. It did not show the charging symbol. Then I connected it to my MacBook. Suddenly it woke up. So what will happen when I don‘t have a MacBook to wake up my Chaarge 3?
By the way, this happened 1 day after I installed the new firmware. A bug?
07-24-2019 10:59
07-24-2019 10:59
It is clear that Fitbit has problems with charge 3. Mine will not stay connected to my apple phone
Best Answer07-25-2019 23:36
07-25-2019 23:36
I have had the Fitbit Inspire for 3 weeks and yesterday it froze completely! I have carried out the suggestions to re-boot it but nothing!!!
very frustrated...suggestions or done return it????
Best Answer08-27-2019 18:00
08-27-2019 18:00
The solution worked once . Now it's broke again
08-28-2019 12:09
08-28-2019 12:34
08-28-2019 12:34
08-28-2019 14:03
08-28-2019 14:03
Many thanks! I will be calling them tomorrow
Best Answer11-24-2019 21:18
11-24-2019 21:18
Fitbit 3 frozen and have followed the steps to reset (hookup to USB/charge cable and hold for 8 seconds). Now all I have is a white line across the screen. The screen is still frozen. What's going on? What can I do now, please?
Best Answer11-24-2019 21:42
11-24-2019 21:42
Freezing Fitbit Charge 3 is obviously still the result of a defect in the device. I experienced this 3 times on 2 years only. In every case I successfully overcame the problem by pressing the side button with or without the cable being attached. Importantly, in one case I had to press the button for about 1 minute. During this time the device reacted several times with display and vibration activities. So, I suggest to keep pressing the button for a longer time. It will eventually come good.
Best Answer11-24-2019 23:35
11-24-2019 23:35
Best Answer11-25-2019 02:12
11-25-2019 02:12
My Charge 3 is less than 2 mths old. It is frozen and the power and 8sec hold has produced only a white line across the screen. When I unplug it the screen is again black and flicks between a screen showing the battery with and ! or the screen awake and notifications or the time face and I can feel it vibrating. Are there other options to get it working. It is my 3rd charge 3 in 18mths and the previous 2 only lasted 7 mths or so. I like it as a device but am thinking I'll have to look elsewhere.
04-09-2020 10:48
04-09-2020 10:48
I followed the instructions about restarting, and I never got the smiley face--I got a horizontal line. And never got the battery icon.
My problem is: the Charge 3 will not charge.
Best Answer04-18-2020 16:02
04-18-2020 16:02
Best Answer04-19-2020 00:44
04-19-2020 00:44
