Fitbit Charge 3 is flashing between screens
ANSWERED
My charge 3 is jumping from time screen to sleep screen and vibrates each time
1 BEST ANSWER
Accepted Solutions
Hello @SpiffyCat Welcome to the community forums! @BenadetteG Thank you very much for your input! I'm glad that the inconvenience is now resolved.
@SpiffyCat I was able to see that you have reached out to our Support Team and they have provided assistance. Since you have received assistance from them, I suggest you to update your case if you require further assistance or if you have any additional questions about the outcome of your case.
Have a great day!
Wilson M. | Community Moderator, Fitbit.
9 REPLIES 9
Hello @BenadetteG Welcome to the community forums!
If you haven't done so, I recommend performing a restart to your Charge 3, by following the steps provided in this help article:
How do I restart my Fitbit device?
Hope this helps!
I have this problem as well. I restarted but nothing changed...
I connected to my charger and held the button for 15 seconds you see a line across the screen. Your watch will reboot.  Take the watch off the charger and then return it to the charger. It should fix it. Mine is going good again
This did not work for me. Even while I have the charging cable connected it still flashed between screens. The line does not appear. Sometimes, it does briefly and flits away. Sometimes a smiley face appears. Usually though it just flips between the time and the DND screen.
Sorry it didn't work for you. When holding the button my line was slow to
go across the screen so the second time I did it I held for longer and it
worked. I contacted fitbit customer service and got a real nice guy called
John. Maybe try the chat and they might know something else you can to to
recover your fitbit.
Have a great day!
Thank you, yes. I chatted with support and they agreed my Charge 3 has failed. A replacement has been shipped to me.
Good to hear you're getting a replacement. Mine is still going good.
@SpiffyCat It's great to hear that a replacement is being sent! @BenadetteG I am also glad to hear that yours is going good!
I hope you both continue tracking towards your fitness goals!
Have a great day!
