06-28-2021
09:44
09:52
WilsonFitbit
06-28-2021
09:44
09:52
WilsonFitbit
My Fitbit charge 3 has stop working, i stopped using it for a while then found it recently put it on charge and it does not turn on, it vibrates when i put it on charge and hold down the button. I tried restarting the Fitbit by holding the button however this did not help. I can't connect it on my phone, it does not vibrate when not on charge and i don't know how to fix it. If anyone knows a solution i could use please let me know, Thank you.
06-28-2021 09:56
06-28-2021 09:56
Hello @Luhburgo. Welcome to the community forums!
Thank you very much for the detailed information and for the troubleshooting steps you've tried prior to posting. Seems that your Charge 3 is not charging and I'd recommend following the additional tips from this help article: Why isn't my Fitbit device's battery charging?
After that, please try to perform a long restart by following the tips below:
Hope this helps.
