09-19-2022 07:18
09-19-2022 07:18
I recently started using a Charge 3 after using a Charge 2 for several years without any issues, but now for several days running I am not getting sleep stages whereas I almost always got sleep stages with the Charge 2.
I know all the tricks from years of experience with the Charge 2 but none have worked so far.
Anything I may have missed?
09-26-2022 12:11
09-26-2022 12:11
I just discovered something which is very likely the key to the problem. I noticed that somehow in my device's Settings that the Heart Rate setting somehow got turned OFF. I don't know how it happened but upon checking my history I discovered that I had no heart rate history since September 15 which was the same date my sleep stages quit working. I'm 99% sure that will turn out to be the problem. I just turned it back ON and I will find out tonight.
09-21-2022 10:01
09-21-2022 10:01
I’ve had my charge 3 for several years without any problems. A few weeks ago it quit recording sleep stages. All other features appear to be working. I’m tightened the band, I wear it higher, I keep it fully charged, and I have reboot the tracker many many times.
09-23-2022 07:30 - last edited on 03-31-2024 09:05 by MarreFitbit
Thanks for getting back to us @ronheller2001 and @jweakley. I'm sorry to hear your Charge 3 aren't registering your Sleep Stages and thank you for mentioning the steps you have followed in order to fix this.
There are a fe scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
Have you checked these scenarios?
09-23-2022 11:12
09-23-2022 11:12
09-24-2022 06:44 - last edited on 03-31-2024 09:05 by MarreFitbit
Thanks for getting back to us and for letting me know that you have tried everything suggested @ronheller2001.
Begin Sleep Now won't register your sleep stages. I'll check if there are other users that aren't getting their Sleep Stages either. I didn't get them last two nights... I haven't changed anything in my sleep so it could be an emerging issue. Let me investigate and I'll get back to you.
Have a great weekend.
09-24-2022 10:06
09-24-2022 10:06
09-26-2022 12:11
09-26-2022 12:11
09-27-2022 09:45 - last edited on 03-31-2024 09:04 by MarreFitbit
Thanks for getting back to us and for your explanation @ronheller2001.
I checked and Sleep Stages are working for my colleagues, I noticed that I have to charge my Fitbit more often and get the Sleep Stages.
Please let me know if turning your tracker heart rate ON helped with your Sleep Stages.
Keep on visiting the forums.
09-27-2022 09:49
09-27-2022 09:49
Yes it worked last night. Looks like everything is fine now.
09-27-2022 10:06 - last edited on 03-31-2024 09:04 by MarreFitbit
Thanks for getting back to us @ronheller2001.
I´m glad to hear that your Charge 3 is showing your Sleep Stages and everything is fine now.
