01-13-2019
15:36
06:00
AndreaFitbit
01-13-2019
15:36
06:00
AndreaFitbit
Hello...
My charge 3 fitbit fitbit screen went totally black
It doesn't response to tapping.
I charged it today to 100%.
3 hours ago it was working fine, i saw the steps the clock everything.
But upon checking now, it shows nothing and it doesn't sync with my phone.
The green light in the back is working and the side touch button is vibrating on touch as usual.
I didn't do any activities like running or anything. I was just sitting in the library when i noticed it.
Please, help.
TIA
01-10-2020 05:06
01-10-2020 05:06
I tried this and my screen came back on too !
But I also have a dim screen I went into settings and change brightness to Normal from auto and was a bit brighter but soon went dim again !
02-17-2020 07:09
02-17-2020 07:09
My Charge 3 is fully charged. Tried changing the clock face a few times. It vibrates when it switches but the screen is still black. I tried the short and long restart and nothing. Any other suggestions?
02-17-2020 07:17
02-17-2020 07:17
I always change the clock face and then manually sync to my phone again to be safe. That has always worked for me so far.
03-03-2020 16:11
03-03-2020 16:11
Last night, my Charge 3 went black. I have tried to restart 3 times, and have tried changing the watchface multiple times. It is still collecting data, I just can't see anything on the Fitbit. Any thoughts?
03-04-2020 06:31
03-04-2020 06:31
Hello,
Mine did the same about a few weeks ago. I tried the long and short restart, change the clock face, forget/pair the device, many-many times and it would only vibrate but nothing else. I contacted Customer Support since I've only had for 6 months and they sent me a replacement. I gave them all the details I could so it can help them determine what is causing this.
03-11-2020 18:13
03-11-2020 18:13
Has not worked for me!
03-11-2020
18:15
06:20
AndreaFitbit
03-11-2020
18:15
06:20
AndreaFitbit
My phone wont sync with my fitbit. I struggle daily with it! Cant change watch face or anything.
That's fine if you can sync it!
Moderator edit: updated post.
03-13-2020 06:05
03-13-2020 06:05
04-01-2020 02:47
04-01-2020 02:47
Thank you so much for the advice. It worked for me 🙂 happy 😃
04-01-2020 05:37
04-01-2020 05:37
04-01-2020 06:58
04-01-2020 06:58
Mine constantly does this. I hate the charge 3 - charge 2 was so much better. The Bluetooth or syncing doesn’t work properly and it has a mind of its own. I charge it then it doesn’t work for a day or two .. all of a sudden it will pop alive and then I have it working for a short time before it needs charging again. I use my charge as a watch and sometimes (sporadically) it won’t work ... so frustrating. I’m afraid it’s an Apple Watch soon .. not sure how much longer I can this!! Also, don’t find FitBit as helpful .. can’t actually send a question (probably hidden in small print) all troubleshooting questions like this. Is it only if you are premium customer so again ££ on top?? Sorry for rant!!
04-21-2020 05:28
04-21-2020 05:28
I have tried every suggestion to bring my Charge 3 back from the dreaded black screen.
Unfortunately nothing including contacting Fitbit has helped!
Fitbit appear to be ignoring this problem, probably because the Charge 4 has been released. The only trouble is that I don’t think too many people who have had Charge 3 problems would risk all the frustration again by turning to a Charge 4.
There is obviously a serious technical problem with the Charge3 and until Fitbit come to the party and can ensure it’s clients that the problem has been addressed in the Charge4 one should definitely not buy this tracker despite all the hype and positive reviews. No review addresses the considerable problem of the black screen. Wondering if they are given a few Fitbit’s to try out or maybe they are just the lucky ones who have had no problems !
05-23-2020 11:53
05-23-2020 11:53
Tried factory reset which has worked before, long reset and changing clock face all to no avail. Before the display died this time, there was a faint white smear down the display. Screen still black, no smiley face. Green light on the back, vibrates when I push the button, battery 100%, tracking steps on app. What more can I do. Very annoying, not even a year old!
06-18-2020 21:03
06-18-2020 21:03
It worked! Thanks! 🤗
06-19-2020 02:39
06-19-2020 02:39
Mine is still not working and I ordered some as gifts to other people so am afraid if their doesn’t work too
06-22-2020 13:53
06-22-2020 13:53
You need to change the "clock face" in your phone app, in the Charge 3 device settings, in the "all clocks" menu. By selecting a new clock face it resets the screen (like resetting a frozen computer) then you will have your Fitbit back! Works every time, happens to me once every few months!
07-05-2020 10:13
07-05-2020 10:13
Changing the clock face worked instantly! No more black screen!!!
07-06-2020 06:04
07-06-2020 06:04
Charge 3, couple of months old, went blank this morning. It is still tracking, battery 100% but nothing that I can see on the screen. Tried reboot, tried long reboot and changing time zone and time face - no success. Any ideas?
07-06-2020 07:58
07-06-2020 07:58
Hi, I think you've exhausted what I know about the blank screen, but the Fitbit is clearly still working so the screen must still be frozen... And if you did the 10second force reboot by pinching the button while it is plugged in and charging, then I think I'm out of suggestions...
07-06-2020 08:23
07-06-2020 08:23
