Fitbit Charge 3 was vibrating sporadically, and now will not respond
Hi,
I have had my Fitbit Charge 3 for approximately a year and 3 months. Yesterday after I got out of the shower, my Fitbit was vibrating like crazy and the screen was turning on and off without me even moving or touching it. It has glitched like this in the past, and usually changing the clock face settles the problem, so I tried that. It didn't fix the problem. After a while I tried plugging it in to see if that would help, and it did actually fix the problem...but wait... there's more...
I was relieved, and I put my Fitbit back on my wrist, and it appeared to be working fine. Later on in the evening I went to check my stats for the day and I noticed that the screen was black, and it wouldn't turn on by pressing the button or touching the screen (no vibration either). I tried to sync it to my phone, and it said "No Device Found." It almost seemed like the battery had died, except for two details: 1) The red and green flashing lights on the sensor are still working, and 2) plugging it in did not charge it or cause it to respond.
What on earth is going on here? Is there something I can do to fix it? And if not, is it covered under warranty?
Thanks in advance.
3 REPLIES 3
Update: late last night the screen started working again, but the button still was not working... I was able to restart it and the problem was fixed! Button working, screen working.
HOWEVER... today it started vibrating sporadically again. I was able to restart it and the random vibrating stopped but now every time I press the button it vibrates twice and goes to the screen that says “screen wake” and “notifications”. There are also several black lines through the screen.
what is going on?????
the same thing is going with mine.  I thought needed to be updated but it doesn't.  I charged it and was fine yesterday but started doing it again.  All I have is the home screen flashing none stop.
Mine is doing the exact same thing...
