08-26-2021
13:04
04:01
WilsonFitbit
08-26-2021
13:04
04:01
WilsonFitbit
Prior to getting my new iPhone 12 the only issue I had with the Charge 3 was that I couldn't see the display in daylight which I gather is a common problem. Now with my new phone it won't stay connected. It says "Lost Bluetooth Pairing Go to Bluetooth settings, forget Charge 3 if it is paired and then go back to app and wait for pairing request". I have done this multiple times and it doesn't help.
Moderator edit: format
08-27-2021
04:07
07:27
08-27-2021
04:07
07:27
Hello @CocoD. It's nice to see you around!
Thank you for the detailed information and for the steps you've followed prior to posting. Regarding the brightness screen inconvenience, I'd recommend taking a look at this thread that contains some tips and suggestions.
For the Bluetooth pairing inconvenience, I'd recommend making sure that there aren't too many devices paired to your phone's Bluetooth; otherwise, please remove other devices paired to your phone and test the behavior of your Charge 3. In addition, I'd recommend performing a long restart to your Charge 3 by following the instructions below:
Hope this helps.
Best Answer09-01-2021 14:40
09-01-2021 14:40
Unfortunately this did not work.
Best Answer09-02-2021 05:58
09-02-2021 05:58
This doesn't work on my Charge 3 and having the same problem.
07:03
07:15
09-02-2021
07:03
07:15
Hello @SunsetRunner. Welcome to the community forums. @jpainedawes Nice to see you around.
I appreciate your help in following the recommended tips. @SunsetRunner Since the inconvenience has persisted, my best recommendation is that you please reach out to our Support Team for further assistance. You can get in touch with them through chat or over the phone by clicking here.
@jpainedawes I was able to see that you contacted our Support Team, but your chat got disconnected while they were requesting some information. In this case, I recommend contacting them one more time and please let them know that you already have a case, this way they can locate your case and assist you from there.
