06-21-2022
11:35
14:14
06-21-2022
11:35
14:14
Part broke and I need replacement Including screws and spring
06-21-2022 15:00
06-21-2022 15:00
Hi @Harley1004 there are no repairs for these devices. You can always ask customer support to let you know what available options are for you.
06-21-2022 11:37
06-21-2022 11:37
Fitbit Charge 4 Replacement Strap Band Clip Holder Genuine Part All Parts x1 This part is broken and I am unable to find replacement part where do I look
06-21-2022 15:00
06-21-2022 15:00
06-21-2022 16:24
06-21-2022 16:24
06-21-2022 16:26
06-21-2022 16:26
Thanks For responding why does Fitbit make it so hard to get parts or repairs and when you do buy parts I can get them they cost as much is the watch
06-21-2022 17:54
06-21-2022 17:54
@Harley1004 some of the people with the broken latch have gotten bands from Amazon which fully encompass the pebble and lets you keep using your Charge 4. You might want to check into it and see if it's worth buying.
06-21-2022 18:04
06-21-2022 18:04
08-22-2022 08:41
08-22-2022 08:41
how exactly do you search for bands that encompass the pebble fully?
08-22-2022 09:13
08-22-2022 09:13
@vmmesa go to Amazon and search "protective cover Fitbit Charge 4" and pick the one that best suits you.
08-22-2022 09:29
08-22-2022 09:29
I bought my replacement on eBay. It is woven and expandable and it cost less than $7.00 and came in a LOT of colors. It was very easy to replace and is more comfortable than the original boring black strap.
08-22-2022 09:35
08-22-2022 09:35
Nice @jezzidog but what the poster was asking was about the band that completely encases the Fitbit pebble where it can no longer attach to any conventional band. I love colors myself!
08-22-2022 10:47
08-22-2022 10:47
The brand names on Amazon are Saufly, Supcase, Kakurookie, Nikki & Goeseth. These are not fashionable but they work, you are looking for bands that look like this picture. Hope this helps.
08-22-2022 21:05
08-22-2022 21:05
Mine broke but not the strap it was the part where you connect the strap. I can’t even put use it.
08-22-2022 21:10
08-22-2022 21:10
@GinaSully by putting the pebble portion of the Charge 4 into the band, it doesn't need the conventional strap. See the post above yours for a picture.
