05-28-2022
09:44
14:23
05-28-2022
09:44
14:23
My fitbit has stopped swiping so I can't get at timers, exercises etc. Tried the Charge 3 fixes but that hasn't worked
05-28-2022 09:55
05-28-2022 09:55
Hello @VMN12
If you long press the side button you see 3 options, you likely enabled SLEEP by mistake, just press that and SCREEN WAKE will enable again. I’m hoping that was the issue.
😃 Let me know if that answered your question and woke your screen up again
Best Answer05-28-2022 12:22
05-28-2022 12:22
Hi checked and Screen Wake is active but still not able to swipe
Best Answer05-28-2022 12:43
05-28-2022 12:43
Hello again @VMN12
Try changing to a different clock face: https://m.youtube.com/watch?v=kEPrWTmhd8Q
😃 Let me know if this fixes the issue
Best Answer05-28-2022 18:43
05-28-2022 18:43
I was having the same problem. Changing the clock face worked. Thanks!
05-28-2022 18:50
05-28-2022 18:50
That’s fantastic news @Keillabee!! 😃 I’m super happy that worked for you. Enjoy your weekend and as always Happy Stepping!
Best Answer05-28-2022 18:51
05-28-2022 18:51
😃 Did changing the clock face work for you as well @VMN12? please keep me posted
05-29-2022 01:20
05-29-2022 01:20
No changed the clock face but still not able to swipe
Best Answer05-29-2022 08:37 - edited 05-29-2022 08:37
I've had this issue for years happening every now and then. The only way I can solve the issue is by connecting it to the charger, holding down the button til the device reboots. fitbit seems to have no idea how to fix this issue. Likely an issue with their software.
05-29-2022 15:25
05-29-2022 15:25
Hi thanks for your response eng3. I have tried this and no luck - even waited until it had fully discharged and tried to reboot it that way but again no luck. I can swipe up and down but not sideways, really frustrating. Good luck with your device
Best Answer05-29-2022 16:51
05-29-2022 16:51
Hello again @VMN12
Have you tried restarting the Charge 4? Here’s how: https://help.fitbit.com/articles/en_US/Help_article/1186.htm If that fails I’d try contacting Fitbit Customer Service: https://myhelp.fitbit.com/s/support?language=en_US
😉I hopefully the restart will work
Best Answer05-30-2022 05:11
05-30-2022 05:11
Hmm, I guess my issue is different. I can swipe to the screen where it says exercise but can't go further.
