05-07-2022
07:37
14:29
05-07-2022
07:37
14:29
Hi,
My Fitbit Charge 4 is unresponsive to taps. If I press the side button once, it does light up and shows me actual stats, but I can't navigate them. This is why I can't restart through the Settings menu. Pressing the side button for 8 seconds (with and without charger plugged in) does not give any result for half of the time. The other half of the time, the DND/Sleep menu items show up but again, tapping them doesn't work. How to reboot my Fitbit (if that's the likely solution)?
05-07-2022 09:59 - edited 05-07-2022 10:00
Hello @Melanie50
When you tried restarting your Charge 4 manually did the Fitbit Logo appear while holding down the side button? Sometimes it takes longer then the 8 seconds you stated. Try holding done the button continuously until the Fitbit logo appears. It might take up to 10-12 secs sometimes before the Logo appears. Sometimes, unfortunately you have to try restarting your Fitbit more then once to get the desired results. The rule of thumb that I read here in the forums is try at least 3 times. If that still doesn’t resolve the issue I’d contact Fitbit Customer Service Here: https://myhelp.fitbit.com/s/support?language=en_US
I’m hopefully that retrying a restart several times gets you back up and running. 😃 Please let me know how it goes.
05-08-2022 08:41
05-08-2022 08:41
Best Answer05-08-2022 09:17 - edited 05-08-2022 09:18
Hello again @Melanie50
Gosh I’m so sorry that trying to restart your Fitbit Charge 4 several times didn’t work and your screen is still unresponsive. I was going to suggest restarting your Fitbit Charge 4 while it’s on the charger but I see you have already tried that. It wouldn’t hurt trying it on the charger a few times. Try putting on the charger for about 30 mins before trying it.
If your Charge series tracker is unresponsive: .
🥺 I’m hoping it will wake up for you. If not Customer service would be next. Please keep me posted
05-11-2022 06:26
05-11-2022 06:26
05-11-2022 07:33
05-11-2022 07:33
😃 I’m crossing my fingers that doing a restart while charging works for ya! Keep me posted
Best Answer08-01-2022 05:28
08-01-2022 05:28
@Melanie50 have u solve the issue ?
i have exactly the same issue ;(
