08-21-2017
12:47
20:15
08-21-2017
12:47
20:15
I bought a Fitbit charge HR, but it won't connect to my phone. It is giving me the code, but when it put it in my phone it keeps saying "connecting". I've tried deleting the app and restarting my phone but it is still not working.
Moderator Edit: Format
08-21-2017 23:54
08-21-2017 23:54
Have you checked that your phone is supported by fitbit at www.fitbit.com/devices ?
08-22-2017 05:12 - edited 08-22-2017 05:13
It's nice to see you around the forums @Honeyizzy, hope you're doing great! Did you check the list of supported devices that my friend @SteveH shared with you? If your phone is listed, but you keep having issues when paring it, I'd recommend double checking if your tracker has enough power to complete the setup process.
If you keep having issues when pairing your tracker after checking its battery, usually a missing requirement is the cause. Therefore, I'd recommend checking these requirements before moving on to the troubleshooting steps:
If you're still unable to set up, try the troubleshooting steps below:
Keep us in the loop, hope these steps help!
08-22-2017 21:03
08-22-2017 21:03
Mine did this too and I force closed the app on iPhone and when I reopened the app it was connected
08-24-2017 07:46
08-24-2017 07:46
Great news @rjleech! I'm glad to hear that this issue was solved by doing those steps.
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community. You can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
Happy stepping!
06-02-2018 18:25 - edited 06-02-2018 20:55
Awesome! Thanks .worked .lost 2 days of worthy steps, but that's tech .
06-02-2018 20:26
06-02-2018 20:26
I've tried these steps over & over but it still wont connect. I don't know what else to do.
06-02-2018 20:56
06-02-2018 20:56
Well, all I can say is after following the exact steps, it worked. If that didn't work, it's defective, demand a replacement or fix. 🙂
06-02-2018 21:01
06-02-2018 21:01
My phone just stopped worked for at least8 months ?
06-03-2018 06:48
06-03-2018 06:48
Hey there, it's nice to see you around @MillieMagic @Fitgus! Sorry to hear that you're still having issues when trying to sync your Charge HR.
Can you please let me know which mobile device are you using to sync? Have you checked if they are included in our list of supported devices?
If the issue persists after checking that your phone is compatible, please go to the Bluetooth settings on your phone and remove the tracker. In the list of Bluetooth devices you'll see the Charge HR and next to it, this symbol "!". Hit the symbol and it will take you to the next step, once you're there select the option that says "Forget this device".
Once you've made sure about that, go back to the Fitbit app, go to the "Account" option in the upper right corner and select "Set up a Device". This should start the setup process for your device.
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below:
If you're still unable to set up, try these troubleshooting steps:
I'm so glad to hear you're back on track after following my suggestions @fretnutt. Thanks for sharing the good news my friend!
Hope that helps, let me know how it goes guys!
11-12-2018 19:22
11-12-2018 19:22
I am having the same exact issue as a commentor above. I am trying to connect my charge HR, but it won’t connect. I put in the 4 digits that pop up on my fitbit and then “connecting to fitbit” pops up and the circle spins, but it never progresses past that. I have tried all of the steps above, and I am using an iPhone X so it’s a supported device. Ive tried these steps 4+ times with no luck.
11-29-2018 19:03
11-29-2018 19:03
so because my charge hr is retired it will never connect in the fitbit app????????
if it will never connect to the app on my iphone x i am really sad that i spent the money to get a charge hr to upgrade from my old flex. I have been trying all day and all night to get it to connect.
11-30-2018 06:28
11-30-2018 06:28
I have followed the steps MarreFitbit has given and still nothing. After I get the #, I enter it in the app and it just cycles with "connecting" I am now on 10 mins still waiting for it to connect. Again I have followed your instructions, my phone Samsung Galaxy 6s has latest version of software, fit bit app has version 2.83. This is beyond frustrating. I now have a useless chunky pink wristband. Please have this resolved or send me a refund for the months I had left on it ($30.00), because lets be real you all designed these to self destruct after 1 year, or send me a credit for a new one when you all get this sync issue resolved.
01-01-2019 09:26
01-01-2019 09:26
I took my wife's Charge HR after mine died and I had to factory reset it before it would connect to my phone. Then it worked.
https://help.fitbit.com/articles/en_US/Help_article/1606
Hope this helps!
01-01-2019 10:57
01-01-2019 10:57
Although my Charge HR synced with my Huawei 5C phone for months, since I recharged it, I have had problems getting it to sync. Consequently it shows the time incorrectly. Spent half a day with tech team trying to resolve (kept getting disconnected, very annoying). Unfortunately I have no alternative suitable devices to test so today I bought a Gogi HR tracker for a fraction of the cost of a Fitbit and guess what? It paired with my phone with no problem at all.
01-03-2019 05:21
01-03-2019 05:21
I have the same issue. My fitbit was connected an just stopped syncing a few months ago.
I have:
A fitbit charge which I have had since 2016, and which has worked on a number of phones, including my current one.
A Samsung Galaxy A3 2018 which has the most recent update on it.
The fitbit app on my phone which is also updated to the latest version (and which used to connect to my watch).
I have followed all the instructions in that I have:
Turned off my bluetooth
Logged out of the app on my phone
Force stopped the app
Turned my phone off and then back on
Reset the Charge HR 3 times
Tried to connect my phone to my HR again but get as far as putting the code in and watching the circle with "Connecting" screen for about 20mins.
IT WILL NOT CONNECT.
Please can you let me know what else you suggest aside from taking a hammer to the bloody thing and finding a fitness tracker that reliably works and will not just stop after 2 years.
01-03-2019 11:40
01-03-2019 11:40
Hammer it. Mine is still not completely fixed. Having to hard reset it every few times is really annoying. And no response from the fitbit experts. So yes, hammer it.
01-05-2019 11:06
01-05-2019 11:06
+1 for smashing it with a hammer. Of all the tech I have ever owned Fitbit is by far the most frustrating. Every few months I have to factory reset to get sync to work again. I have spent most of the day trying to get my charge HR to work following the instructions above dozens of times. Just like I did in the Autumn and again back in the Summer. It never ever works without a factory reset which deletes all the data. Absolute pile of c**p. I wont ever buy another fitbit again.
01-06-2019 03:50
01-06-2019 03:50
So after finally factory resetting my Charge HR I managed to get it to connect for a whole half a day before it would no longer sync or connect.
So this has to go. Having a fitness tracker that you cannot actually connect to anything is pointless.
Is this only a CHARGE HR issue, or is it a FITBIT issue? I need to know this before getting another tracker because I am not getting another Fitbit f I am going to have this challenge with all the models. So can someone from Fitbit let me know if the other models are having the same issues. And also I would appreciate if they could let us know why this is an issue with the Charge HR (which it clearly IS judging from the comments on this thread and the other threads about the Charge HR not connecting).
01-06-2019 06:37
01-06-2019 06:37
Thanks for detailed step by step.
i have tried everything but I am still unable to get my Fitbit to sync with my phone.
i have removed the app, and started again- even on a new phone.
i went through the steps restart the phone and watch.
i switched off the Bluetooth as suggested.
still no luck. My phone can't find my watch.
what now??
