02-17-2019
12:13
20:07
02-17-2019
12:13
20:07
My husbands fit bit is really hard to see, the numbers are very faint, despite it been fully charged, any one know why cheers lynne
Moderator edit: Updated title for clarity
07-14-2022 09:23
07-14-2022 09:23
It was my favorite device. I have since thrown it out the window. They apparently couldn't( wouldn't) fix the issue as the newer devices are not " expensive" enough to where someone can't just buy a new one. Oh well, on to Garmin.
09-30-2022 03:15
09-30-2022 03:15
yes this display problem is not acceptable. My Fitbit was my first watch and i liked the purity design. 4 years ago I changed to Garmin. Works fine with iOS Health sync. I reactivated my Fitbit to test, but now have the same problem with the dark display. The hardware quality is definetly not good enough in this price class.
11-09-2022 07:21
11-09-2022 07:21
Same problem here. I simply solution that I will never buy Fitbit again.
11-09-2022 09:45
11-09-2022 09:45
I bought an Apple watch SE earlier this year. Works great with my Google Nest doorbell / camera. The watch gets a notification and an image when we have callers. It can also notify you when a parcel is delivered. You can also respond to the doorbell. It links to my iphone and if the phone is close enough, I can take and respond to calls via the watch. Only really negative point is it needs charging every 2 days.
11-18-2022 09:31
11-18-2022 09:31
Thanks for the info. Where am I supposed to swipe right exactly? I’ve looked through the app and I can’t find the display brightness.
01-18-2023 10:16
01-18-2023 10:16
I use mine sporadically, but the display was dim, so I went in to settings and it was set to "Normal" so I thought "OK, let me try to set it to "High" (assuming that was an option).... Well, I tapped it once, it went to "Auto" and now I can't see ANYTHING. This was a simple device that did what I needed, but now is useless. WELL DONE GOOGLE\FITBIT. You'll get my vote on product quality by how I spend for a replacement, which won't be a Google product.
01-19-2023 09:12
01-19-2023 09:12
