09-06-2019
03:36
05:17
JuanJoFitbit
09-06-2019
03:36
05:17
JuanJoFitbit
Hi,
I am new to Fitbit and I’ve really enjoyed the Sleep Score function. However, as of yesterday the app is no longer providing a sleep score. The sleep insights are turned on and are displaying the different stages of sleep, but the analysis as well as the score have simply disappeared.
I have tried logging out and back in, as well as toggling the sleep insights tab. None of this has worked. Can anyone advise me on why this is happening and how to fix it?
07-21-2020 16:44
07-21-2020 16:44
Best Answer07-30-2020 03:36
07-30-2020 03:36
WHAT HAPPENED TO THE SLEEP Score? I see no true answer in the community. I’ve had my Fitbit for a while and the sleep score has been gone for months.. I’ve tried the things suggested but it’s not there. So when will this be fixed ??
08-07-2020 09:37
08-07-2020 09:37
None of the suggested fixes have worked. My Inspire HR has given me sleep scores (and details on sleep stages) since I bought it 5 months ago, and then as of 8/1/20, I only get the sleep graph with no score or ability to see sleep stages. It is blank. The app is updated, and I've never used the going-to-sleep-now option. I just went to bed and it recorded my sleep. I'm so frustrated b/c this is the whole reason I bought this watch. Any other suggestion besides what has already been posted here?
08-26-2020 07:46
08-26-2020 07:46
Haven't gotten a sleep score since early June. Any update to this problem?
08-27-2020 05:06
08-27-2020 05:06
Why is this marked solved?
09-13-2020 23:03
09-13-2020 23:03
I found that as long as I let the system work, without intentionally telling it I was sleeping, it logged my sleep. Try it. When I told my fitbit I was going to sleep, I never got the log. When I just went to sleep....it was there.
09-28-2020 10:24
09-28-2020 10:24
After an entire year with this non-answer, what has Fitbit done to resolve the problem?
10-31-2020 20:50
10-31-2020 20:50
Well, I have not received a sleep report for a week, and other weeks it has been spotty. It is November 2020. Thanks
11-09-2020 09:41
11-09-2020 09:41
No details or sleep score since October 21st.
11-27-2020 16:11
11-27-2020 16:11
Just happened today. Had a sleep scores consistently, except when under threshold, and today 6 hrs sleep and no score. Tried reinstalling ap and still no score. Can't find the supposed answer to the problem.
11-28-2020 18:41
11-28-2020 18:41
This happens to me frequently (Charge 4).
If I delete the bad sleep log and then add the sleep back manually, the sleep score and sleep stages always appear correctly on the manual one.
I just have to remember to take note of the sleep times before deleting the bad log, since it needs those times to add it back.
I have no idea why it doesn't record it correctly sometimes. It has nothing to do with how I'm wearing the Fitbit. But at least whenever it screws up, I can just delete it and add it back for the full info.
Best Answer12-03-2020 06:37 - edited 12-03-2020 06:40
Deleting (or adding) and re-adding the sleep log usually works for me, though it's annoying I should even have to do that half the time. For the last 2 days, my Inspire 2 hasn't recorded sleep at all, and no score or stages show up if I add a sleep log. I'm wearing it at the same tightness - 5th to 6th hole- as always, same wrist, same bed, same schedule, similar sleep position.
ETA: rebooting the tracker itself fixed it. That's a new one for me.
Best Answer12-08-2020 04:25
12-08-2020 04:25
This worked perfectly!!
Best Answer12-12-2020 22:36
12-12-2020 22:36
Same happening here.
Best Answer12-21-2020 07:28
12-21-2020 07:28
Same with me! My Inspire 2 sleep score data showed up the first two days and never since. I contacted Fitbit and they said they are working on it. Periodically I’ll get an email thanking me for my patience and asking me to restart my device, which I’ve done many times already. Very frustrating!
Best Answer12-21-2020 07:33
12-21-2020 07:33
It is on and still doesn’t work.
12-21-2020 12:11
12-21-2020 12:11
12-22-2020 04:07 - last edited on 12-23-2020 15:41 by LiliyaFitbit
like Lydia said, not starting the sleep log at all has been working for me for weeks. Just go to sleep. The device has been automatically sensing and recording sleep.
Moderator edit: format
Best Answer01-05-2021 08:41 - edited 01-05-2021 08:42
I just started using my Fitbit Charge 3 again and have the same issue. No sleep score but I do get the graph. I really like the sleep score but looks like there isn’t an answer for over a year. I might look at Apple Watch.
Best Answer01-07-2021 20:06
01-07-2021 20:06
Having same problem, have done everything Fitbit suggested, even wore on inside of wrist one night and still no sleep scores.
