10-15-2019
12:23
12:06
10-15-2019
12:23
12:06
IOS 13.1.3 Iphone 10 fitbit scale IS communicating with the app
Bluetooth is on and shows Charge 2 connected
I then....
Reset the fitbit no change
Turned Bluetooth off and on no change
Turned Iphone off and on no change
Then I Upgraded latest IOS to 13.1.3 and repeated above steps with the same error message
HELP!
10-16-2019
09:00
06:03
10-16-2019
09:00
06:03
@fendermc Welcome! Thanks for being part of our Community!
Let me help you with your Charge 2 not syncing with your iPhone and thank you for troubleshooting this issue. You can try the following:
Let me know how it goes.
Best Answer10-16-2019 09:25
10-16-2019 09:25
Chat solved. Iphone; Settings, Fitbit, set bluetooth to on -
Somehow after the IOS upgrade it was moved to off - Solved but also do all the resets and even though the device is not yet discovered in Bluetooth run the app and it connects and solves the Bluetooth connection.
Best Answer10-16-2019 09:26
10-16-2019 09:26
Thanks Man - solved through chat - fix is described /responded to in my post appreciate your time
10:09
06:42
10-17-2019
10:09
06:42
@fendermc thank you for your update and happy to hear that the issue was resolved by our Support team. Also thank you for letting us know what fixed the issue as this may help other members in the Community.
I'll be around.
