03-09-2016
18:34
20:15
03-09-2016
18:34
20:15
04-21-2016 17:52 - edited 09-07-2016 16:14
Hello guys @jlebda207, @Eweidman, @kpritch! It's great seeing new faces around. In this case I would recommend following these steps for further troubleshooting:
For iOS:
- Turn off Bluetooth, turn it back on, and then open the Fitbit app.
- If your tracker didn't sync, force quit the Fitbit app and open it again.
- Reboot your mobile device and then open the Fitbit app again.
- Restart your tracker again.
- Also, you might want to try setting it up from a different device such as a computer.
For Windows phones:
- Close the Fitbit app and open it again. A sync should occur whenever the app is opened.
- Restart your tracker.
- Uninstall and reinstall the Fitbit app.
- Try syncing with your computer.
- Set up your tracker as a new device following the instructions
For Android devices:
- Consider using the All-Day Sync setting. This prompts your tracker to periodically sync with the Fitbit app but may cause increased battery drain on your mobile device or tracker.
Let me know if this works guys!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
03-09-2016 19:07
03-09-2016 19:07
Same here. Fitbit Charge HR worked well with windows phone for about 3 weeks. Then something happened and it would not sync with my phone at all. I am not sure what caused it to happen however, I did turn on and off the stopwatch function a couple times about the time that the fitbit stopped syncing. Who knows. It would be nice if fitbit contacted their customers and told them what is going on. They have our email addresses and our accounts, so it should not be so difficult.
04-20-2016 13:24
04-20-2016 13:24
I got a new fitbit a few months ago. Since I got it, it does not give me a weekly update on phone or computer. Also, time is not correct. How do I change time
For iOS:
For Windows phones:
04-21-2016 19:19
04-21-2016 19:19
I had to turn my bluetooth off and back on again for another device. And no matter how many times I've reset my Charge HR, IPhone 6, deleted the app and reinstalled, turned off bluetooth and wifi, I cannot get my Charge HR to pair with my IPhone or Macbook. I've sought help from the phone support and chat support and have had no luck. They've offered me a 25% discount towards the purchase of a new fitbit, but only if I return my fitbit to their offices.
04-22-2016 10:46
04-22-2016 10:46
04-22-2016 15:29 - edited 04-22-2016 15:57
Hello @cshelle24 & @kpritch! welcome to the forums. @cshelle24 in this case, I'd give a try to what @kpritch is suggesting and then keep us posted with the outcome!
07-25-2016 17:20
07-25-2016 17:20
07-25-2016 20:44 - edited 07-25-2016 20:58
I had similar problems and it freaked me out. This usually hampend when my Fitbit was completely discharged, no battery, dead as a door nail. Plug it in to your charger and walk away. Give it plenty of time to recharge. Delete your Fitbit from your iPhone and re-link as instructed putting the new number from your Fitbit into your phone app. It should link. Never let it run out of battery again or you will have to repeat this whole process again. Good luck!
09-07-2016 16:18
09-07-2016 16:18
@Rcarroll0623 thanks for trying the troubleshooting. If nothing has work, then I suggest contacting our Support Team for a second opinion. They definitely have the proper tools to take a deeper look into your tracker's behavior. Good luck and keep me posted!
@kpritch thanks for sharing your solution with the community! This is definitely going to help other users experiencing the same issue! Thanks for participating in the forums, hope to see you around more often!
01-06-2017 04:38
01-06-2017 04:38
None of these solutions worked for me. I turned the Bluetooth off on. MY phone yesterday and now my iPhone can't find it at all. It worked like a charm yesterday. It's very strange. It did connect to my iPad, which is strange too. The iPad is not a solution though since I can't take it in runs, etc. any ideas?
01-06-2017 04:40
01-06-2017 04:40
I have a charge2 and was loving it until this happened. 🙂
01-08-2017 12:49
01-08-2017 12:49
Hi there,
I have tried the suggested solution and experience the same problems as othe users. I have tried setting up the fitbit on two different iphones and neither has worked. It gets as far as recognising the HR device is there, I am provided a pairing number to use, I enter it into the app and nothing happens for about 5mins then I get an error message that goes off the screen too quickly to read what it says, and the device remains not set up. please help.
01-08-2017 13:40 - edited 01-08-2017 13:43
@Ncfootes it's nice to see new faces around in the Community! Please follow these steps for iOS syncing troubleshooting.
On a different note, I'd like to kindly ask if you could post future questions in the Charge 2 board as this is the Charge HR board. In the right board (Charge 2), you'll find more relevant info related to your tracker. Thanks for your help on keeping the Community a tidy and organized place. If you're not able to find an existing topic, feel free to start a new one. Good luck!
@tkmcooper123 thanks for stopping by! Have you tried restarting your Charge HR? If not, then I recommend doing the following:
If that doesn't do it, follow these troubleshooting steps for set up issues. Good luck and let me know how it goes!
01-08-2017 18:41
01-08-2017 18:41
01-09-2017 13:09 - edited 01-09-2017 13:11
My Charge HR died. I had recharged it and then I could not connect, I deleted the device from both fitbit app and Bluetooth devices, reinstalled the app, nothing. Then followed the instructions to restart my tracker, (http://help.fitbit.com/articles/en_US/Help_article/1186) referenced in MariamFitbit's post and woot got it! NP. Probably should have restarted the tracker first and saved time.
01-09-2017 14:51
01-09-2017 14:51
Thank you! I haven't used my charge hr since May, was eyeing up charge2 but can't afford atm! So glad to have my Fitbit back!
01-19-2017 20:17
01-19-2017 20:17
None of the above solutions did a thing. Plus, how do you sync with the computer. When the fitbit is in the charger the buttons are obstructed. I regret buying this tech gear which doesn't work! Poor performance fitbit, I'll be replacing asap and you've lost another customer.
01-19-2017 20:33
01-19-2017 20:33
SO your answer basically is, reboot. Doesn't work, regardless if I am just closing the app, or rebooting the phone, or restarting the fitbit, or shutting bluetooth off and turning it back on. Do you have any real solutions? Can I get the money back that I wasted on this Fitbit Blaze 2 months ago? It used to work, synched for awhile, but no longer. Please advise.
01-19-2017 22:18
01-19-2017 22:18
I have tried all the suggestions. I too like other users have been asked unable to make the sync work. This Fitbit was a replacement from you for another one that stopped working in Summer last year and this one has not worked either. My husbands fitbit stopped working too. I would really like a refund for this brand new item that simply does not work.
