03-09-2016
18:34
20:15
03-09-2016
18:34
20:15
05-06-2017 03:03
05-06-2017 03:03
I've just received a replacement Fitbit. How do I sync it to my account please.
05-09-2017 14:09
05-09-2017 14:09
Also having problems.... but found that connecting my fitbit to my computer via the USB cable has at least allowed the phone to recognize the fitbit. It's a start!
05-10-2017 19:31
05-10-2017 19:31
Tried all the suggestions and none of them worked.
05-16-2017 18:14
05-16-2017 18:14
@amoff11 & @Janis thanks for joining us and for your feedback. Hey, have you guys tried setting up you trackers as replacements? If you haven't already please check the following post to do so.
@amoff11 As far as I know there is no way to factory reset your Charge 2. Hey just as a friendly reminder, please post your Charge 2 inquiries in the Charge 2 board. This will definitely provide more relevant info related to your tracker and it will help us to keep the community organized. Thanks for your understanding!
@MrsDoz please check out this post to set up your replacement. Good to know that you received one! Oh and welcome to the Community!
@lmpie94 it's nice to see new faces around! Have you got your Fitbit Charge HR syncing again through the charging cable? Do confirm that to me! Also, have you tried restarting your tracker? If you haven't already, please do the following:
Hope this helps guys! Keep me posted.
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
06-10-2017 05:50
06-10-2017 05:50
... tried this for ages, then realised I had a tablet synced to my Fitbit- I switched this off and then went to the Fitbit app- it didn't work until I pressed 'sync' now (or similar- under the 'all day' button)- problem solved 👍
06-11-2017 14:03
06-11-2017 14:03
@rmammatt awesome news! Reading that your problem was solved was like a ray of sunshine!
I'd like to invite you to our Lifestyle Discussion Forums. There are lots of interesting topics; my favorite is "Eat Well" since I love food!
06-11-2017 15:23
06-11-2017 15:23
Thank you- I look forward to reading the articles (need all the help I can get!)...
06-12-2017 13:31
06-12-2017 13:31
@rmammatt sure thing! Feel free to post back if you have any other inquiry.
Hope to see you around more often!
06-14-2017 20:48
06-14-2017 20:48
I had a Charge HR that needed battery charging every other day AND either turning off/on tracker and/or my iPhone. Unfortunately, first replacement tracker was a dud, per Tech Support so another one was sent. After 2 1/2 hours on the phone with 2 different support techs (first one disco'd at 5:00 pm, a surprise to me), finally got the 2nd replacement synced and working. Turns out there is a known issue with both iPhones and Windows, which I was told after tracker wouldn't sync with either iPhone or PC. Very maddening, to say the least!
06-15-2017 06:39
06-15-2017 06:39
@MARILYN.VOYLES thanks for joining us and for providing us with your feedback. I'm glad to read that your 2nd replacement is working as it should. I'm assuming Our Support Team guided you trough some troubleshooting steps; however, I suggest reviewing this post with some other troubleshooting steps for future reference. Maybe there's there something that might help for your tracker.
Feel free to post back!
06-15-2017 09:11 - last edited on 06-16-2017 12:07 by SunsetRunner
I cannot comprehend why fitbit now has such dreadful programming that they expect their customers to spend hours and hours to pair or sync their trackers. After spending 2 1/2 hours with 2 support techs in a chat, finally got my replacement Charge HR to sync - ONCE. I do not have enough hours in the day to spend with fitbit to get your tracker to work properly. Disgusted with how downhill trackers and/or programming have gone in the last year or so.
Tracker is not pairing AGAIN with iPhone 5.
My tracker synced one time, around 6:30 PM, from my iPhone 5. Now it won't sync at all. I have done all the steps outlined, with my brand new replacement Charge HR, numerous times and it still will not sync via my iPhone 5 or Windows 10 computer. I am about to give up. My husband already said no way he'd get a fitbit after seeing what I'm going through. Further, like a dummy I did what last Tech Support person told me to get new tracker to pair, and now have to repair with my car and everything. Last words from Tech Support is that these are known software problems w/iPhones & Windows and engineers are aware. Both are what I use and very different items?
Just to clarify...I have no tracker that will pair at this time, rendering my Charge HR useless except as a watch and I have much nicer ones.
Not my issue. Nothing else is paired.
Just got this recommendation from chatting with a different Tech - to factory reset my Charge HR by following this: https://help.fitbit.com/articles/en_US/Help_article/1606/?q=factory&l=en_US&fs=Search&pn=1
Plan to try this tomorrow after spending literally over 4 hours on the replacement yestereday.
Moderator Edit: content
06-28-2017 05:15
06-28-2017 05:15
None of this has worked. My fitbit has been syncing for months and up til a week ago. Now on my Android phone, on my pc, they don't see it. I've closed/removed the app, turned bluetooth on and off on both, done everything I've read and nothing works. Neither one sees it anymore. I've just finished a challenge very short of points because this thing stopped working a week ago and I've been struggling with it ever since. Beyond frustrated. This is the second one I've battled with. Think it's time to move to another brand.
06-28-2017 06:15 - edited 06-28-2017 06:34
Okay, So I've been using my Fitbit non stop since I had the item and I've loved using it. However silly me lost the charger for it and so I didn't use it for a few days as it was flat. When I finally found the charger and been using it since, the Fitbit doesn't want to always want sync. There are times when I have to try a couple of attempts for it to do so and then there are times when I have the error message come up.
I am trying to sync it currently and am on my 6th attempt Grrrrr!!!!
I not sure if this is my fault for letting it go completely flat for a week max or if this is the product. The Fitbit was brought last Christmas time, but I have no proof of purchase as this was bought for me, I also don't want to have to send it back if the problem is fixable.
It really annoys me that it will not sync first time like it did.
Any suggestions? please help me!
06-28-2017 06:23
06-28-2017 06:23
I had the same issue when setting my Fitbit up to my phone. I tired with the Ipad and this worked, I then tried to re sync with my phone and eventually it worked.
So if you have another device with Bluetooth try using that and seeing if you can connect, sot sure if anyone as suggested it already, so if they have apologies for repeating it 🙂
06-29-2017 02:36
06-29-2017 02:36
06-30-2017 07:16
06-30-2017 07:16
I have tried all the suggestions and I can't sync for 3 days.
06-30-2017 17:49
06-30-2017 17:49
06-30-2017 21:59
06-30-2017 21:59
07-10-2017 12:19
07-10-2017 12:19
Greetings everyone!
@MARILYN.VOYLES @MolokaiGirl @FaithJade @Meemaw3 @Sandyo1249
Thanks for troubleshooting this issue guys! As a last resort I recommend trying to repair your tracker by following these steps:
After doing that, attempt a sync and let me know how it goes!. This has worked for me in the past.
07-14-2017
07:55
12:27
MariamV
07-14-2017
07:55
12:27
MariamV
I tried all the steps you've given for Android and they are not working. I just got this charge 2 not even a week ago. I have it set to all.day sync but when I go to refresh the sync myself it does not work.
Anything else I can do?
Moderator edit: fotmat
