04-03-2016
14:10
17:01
04-03-2016
14:10
17:01
04-05-2016
12:11
06:13
04-05-2016
12:11
06:13
@Jene66 Welcome to our Community! Many of our members that have lost weight do mention that their trackers become a little bit loose on their wrist. I just want to mention that we don't recommend you modifying your tracker as this will void your tracker's warranty.
I'll be around!
05-02-2016 16:06
05-02-2016 16:06
Yep! I had the same problem. I lost 65 pounds in 4 months, and now my Charge HR is too big. Fitbit Customer Service just basically told me I'm out of luck. Horrible design flaw, and we are paying the price for it.
05-03-2016
12:18
06:12
05-03-2016
12:18
06:12
@Merk54 Welcome to our Community! Wow 65 pounds lost in 4 months! Well the fact that you have had such a drastic change in your body is the reason you don't feel comfortable with the size of your tracker anymore. Still you can get the most out of your device. Try wearing it as tight as the device allows it. Hopefully you will keep achieving your goals and have a better and healthier lifestyle.
I'll be around!
05-05-2016 15:24
05-05-2016 15:24
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
09-02-2016 08:24
09-02-2016 08:24
I had the same problem. I simply took a Dremmel and cut off the outer most fastener which allowed the inner one to move up 2 spaces. Then, to make sure it didn't fall off (as if that style band ever did with the 2 fasteners) I purchased some silicone fasteners from Amazon (from a company called "Friendly Swede" ) for $6 to make it more secure if it should come unfastened. Actually, I was using these fasteners already as mine had fallen off a number of times and I even lost one due that design problem. A bit of a hassle? Yes...But solved the problem and at least I am wearing mine instead of trash-canning it.
09-08-2016
07:28
06:12
09-08-2016
07:28
06:12
@GaryWill Welcome to our Community! Thank you for sharing your suggestions and for the detailed explanation. This may help other members that may want to try it.
I'll be around!
12-11-2016 09:55
12-11-2016 09:55
Well...While my "fix" worked for sizing, the fitbit unit is now working its way out of the casing of the wristband. The wristband is peeling away on the edges of the unit and the unit has cmpleel released itself from he rubberized wristband on one end. Everyone I know had similar problems with thr od wristband, including myself, and all who have the better designed wristbands (which also don't simply fall of one's arm without having to purchase and use silicon bands to secure it) with clasps are having no issues at all. Do you think that support would consider a replacement or some kind of work-around to repair these bands? The fitbit unit works perfectly.
12-16-2016
06:53
06:12
12-16-2016
06:53
06:12
Hey @GaryWill, thanks for join the Community!
Sorry to read the issue with the wristband of the Fitbit, I suggest to contact our Support Team so they can take a look in your account and offer you all the options available. You can contact them via email, or if you're in the US you can reach them via live chat or calling at (877) 623-4997, they work from Monday to Sunday, from 4am to 9pm (PT), I'm sure that they'll be glad to assist you!
Please let me know the outcome.
What's for breakfast?Check others recipes and share yours!
02-26-2018 15:39
02-26-2018 15:39
I just bought a new charge 2 small and wristband is too large even at the last hole. this should be corrected.
01-12-2019 21:29
01-12-2019 21:29
I bought a Fitbit charge 2 that worked great for a month. Now it’s not tracking my sleep and feels too loose. I have it attached as tightly as possible. And I plan to lose weight. There should be a way to add another notch so I can make it tighter. Or I should be able to buy a tighter band. I have a large now. Should I just throw it out and purchase from a better company next time?
06-30-2021 20:31
06-30-2021 20:31
Wow what an unhelpful comment
06-30-2021 20:32
06-30-2021 20:32
Are you having a laugh awful customer service, you were great before google bought you
