03-07-2018 12:26 - last edited on 09-06-2020 20:15 by MatthewFitbit
My daughters charger hr ran out of battery and had wrong time when recharged. We tried to sync it to update time but it wouldnt sync. I have restarted fitbit, android phone and app before removing and reinstalling app. App connects with fitbit and asks for 4 digit code but then sticks on this page with the connecting icon endlessly spinning. I have retried numerous times but with same out come. HELP
06-20-2020 06:49 - edited 06-21-2020 11:04
Hi there,
I charged my Charge HR and tried to sync it to my Samsung S7, no luck. I jumped on the forums and looked at what worked for others. I followed all the recommendations:
- restarted fit bit
- restarted my phone
-uninstalled the app on my phone/reinstalled the app
- Bluetooth off and on
-factory rest of the fitbit
- forgot Bluetooth pairings
- forgot my hr in the app
- if it’s recommended to try, I’ve done it...
nothing has worked. The fit bit is running, but has the wrong date, time, and won’t connect to my phone. Each time I try to pair it, sometimes my phone sees it to pair, but eventually it times out and states that the HR rejected to pairing. It really is a shame. What else haven’t I tried? Help please!
07-27-2020 03:44
07-27-2020 03:44
I found the issue to be with app permissions. I went into app settings on my phone and allowed permission for storage. It's now working.
09-06-2020 03:46
09-06-2020 03:46
The annoying recurring problem of an inability to properly sync happens every once in a while. The recommended turning Bluetooth on and off did not work. I finally turned the phone off I holding all buttons until it restarted. That worked Good luck
11-02-2020 13:02
11-02-2020 13:02
Hello, I am having the same problem can you help me too?
11-02-2020 13:38
11-02-2020 13:38
11-02-2020 13:49
11-02-2020 13:49
You are the best!!!
05-06-2023 17:52
05-06-2023 17:52
I've been having the same problem and tried all the steps with no success -- restarting my Charge HR, reinstalling the app, turning Bluetooth off and back on (I usually have it turned off except when needed), turning the phone off and back on, ... , everything except a factory reset of the Charge HR. Nothing worked. Finally, I went to my phone's Bluetooth menu and clicked on "Pair a new device." That found my Charge HR and, after a couple of confirmations, paired successfully. The Fitbit app still said it needed to pair, but this time was able to do so successfully. 😀
So, that's my solution. Let the phone's own Bluetooth menu do the initial pairing, then the Fitbit app will be able to pair successfully,
