09-15-2021 08:41
09-15-2021 08:54 - edited 09-15-2021 08:55
Was the Charge 3 on your arm, or on the nightstand @lisa_sd
The only option we have for removing steps is to mark the time as driving..
09-15-2021 08:55
09-15-2021 08:55
@Rich_Laue it was on my wrist with about 80% charge.
09-15-2021
11:58
11:23
09-15-2021
11:58
11:23
Hi there @lisa_sd. Thanks for your help @Rich_Laue.
Thanks for sharing detailed information about this situation. I understand your concern as this isn't the expected behavior of the Charge 3.
To take a look into this may I know if you logged some activities? Or do you have MobileTrack setup in the Fitbit app? MobileTrack is a feature that records basic stats such as steps using your phone's sensors if you don't have a Fitbit device available. While you didn't have a fan nearby, you might have received incorrect steps if your phone vibrated while you were sleeping.
While we are not able to remove the steps you can log a drive activity as @Rich_Laue has mentioned before, to override those steps, see here to get instructions.
See you around.
09-19-2021 13:43
09-19-2021 13:43
Thanks @CindyMFitbit I guess I'll have to do that. I had a ceiling fan on low but I can't imagine that would trigger 80,000 steps in 15 minutes. Is there a way to submit this defect to Fitbit for further investigation?
09-19-2021
15:52
11:23
09-19-2021
15:52
11:23
Thanks for your response @lisa_sd.
It is not not usual that this happens, but as I have mentioned, sometimes the devices are able to detect steps, if there is something vibrating near by, but if you notice that the issue persists after taking in inconsideration the information provided before, you can let me know so I can transfer this information to be reviewed.
Also you can contact our support team and provided all the details since they have special tools to continue assisting you. Click here to get connected.
See you around.
