06-09-2019
05:45
15:29
06-09-2019
05:45
15:29
I recently had to restart my Charge 2. Everything is working great, but I am no longer getting notified when I have a call or text. I checked and the notifications are turned on. Then I deleted the device and repaired it to my phone. It is still not working. Any suggestions?
06-09-2019 06:06
06-09-2019 06:06
When you say you checked that notifications were turned on, did you check both the app and the Charge 2?
A common cause of this is where the Charge 2 is accidentally put into "do not disturb" mode. This is turned on / off by pressing and holding the button on the Charge 2. Could this be the problem here?
06-09-2019 06:06
06-09-2019 06:06
06-09-2019 07:52
06-09-2019 07:52
I just upgraded from galaxy s4 to s10e and evidently it is not o The supported devices list-I can't get notifications on my charge 2. My boys told me to switch to Garmin and be cool like them...may have to even though I like my charge 2.
Best Answer06-09-2019 11:38
06-09-2019 11:38
Best Answer06-09-2019 11:43
06-09-2019 11:43
Holding the button down toggles the setting. If notifications are off, holding the button turns them on and vice versa.
06-09-2019 13:40
06-09-2019 13:40
Mine did this. Fitbit sent another as within 2 yr gyaranree2
Best Answer06-10-2019 12:11
06-10-2019 12:11
