11-23-2018
04:26
14:34
11-23-2018
04:26
14:34
When I wear my Charge 3 to sleep, I wake up to a red light flashing with the green. If I take it off and put my thumb over the sensor, I'll get one red flashing, then the green and red rapid flash together. Restarting seems to stop it, but I don't want to have to put it on the charger every morning, nor do I think that's more than a band-aid on the problem. Can anyone offer a permanent fix?
11-23-2018 04:43
11-23-2018 04:43
Is it a problem to be fixed?
Some people have speculated that the red light is to do with the SPO2 sensor.
11-24-2018 06:13
11-24-2018 06:13
If it's not a problem, I'd definitely like to know!
01-02-2019 13:32
01-02-2019 13:32
Hi @Screaming-Tiki,
I believe that is for assisting the green light in finding you sleep stages as you can see on the app. Because you only need to see sleep stage when you are asleep it is only on then.
And here is a link for another forum about this.
https://community.fitbit.com/t5/Ionic/Red-Sensor-Light-was-ON/td-p/2922932
I hope this helps! 😀
Random_Person
02-17-2020 04:06
02-17-2020 04:06
The same thing happened to me today
