09-26-2019
02:24
10:43
09-26-2019
02:24
10:43
Hi,
All of the sudden my Fitbit charge 3 started to flash and constantly showing the wake up screen and notifications. It drains my battery so much that after 3 hours I need to charge again.
i have reset the device few times but still got the same issue. Is my device faulty?
09-26-2019 03:28
09-26-2019 03:28
Hi @KamilaM try a long restart, but if that doesnt fix it, please come back here
CHARGE 3 LONG RESTART
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable. Plug the device into the charging cable again. The smiley face icon appears on the screen.
Helen | Western Australia
09-27-2019 01:24
09-27-2019 01:24
Thank you!
it worked!
Best Answer09-27-2019 01:46
09-27-2019 01:46
I have the same problem. Long restart didnt help. Is there a way to undo this version?
09-27-2019 02:19
09-27-2019 02:19
I am sorry to hear that.I also updated iOS to 13.1 and long reset and it worked.
Best Answer05-10-2020 07:23
05-10-2020 07:23
It worked temporarily for mine and then has restarted again. The clock was also wrong. had to re pair with my phone. should i down load a new Ios? will that help?
Best Answer09-08-2020 05:24
09-08-2020 05:24
Long reset did not work for me any other suggestions would be greatly appreciated.
09-09-2020 01:37
09-09-2020 01:37
Hi @Cshearin You will need to contact Customer Support
