02-08-2019
09:40
17:54
02-08-2019
09:40
17:54
Since the update (I think) the food log is very uncooperative. If it doesn't give an error when I try to log it in, it records the calories and the food item, but then I still have eaten 0 calories and the numbers above don't match.
So I recorded a custom food at 356. The summary says 0 cal in --797 cals out, 672 calories left in your budget. (My budget is set to be -250)
The home page reads 0 cal in 1380 out.
Yesterday I just did a quick calorie because that is all it would take. I did it 3 times. The dash says I ate the 3000 cal but the summary in the food log says 0.
This is really messed up.
My starting weight was 146.2. My last recorded weight is 144.2. the app says I have lost .8 pounds since the starting weight date. Go figure. I would like to see my full 2 pounds please. I need the motivation!
02-08-2019
22:39
05:26
YojanaFitbit
02-08-2019
22:39
05:26
YojanaFitbit
I have a Charge 2. I ended up deleting the app and re-installing it. That seems to have helped. Why was this necessary?!
____________________________________________________________
1 Simple Trick Removes Eye Bags & Lip Lines in Seconds
Fit Mom Daily
Moderator edit: Removed personal information.
Best Answer02-08-2019 14:53
02-08-2019
22:39
05:26
YojanaFitbit
02-08-2019
22:39
05:26
YojanaFitbit
Fit Mom Daily
Best Answer02-08-2019 22:44
02-08-2019 22:44
Sorry, the app is on an Android phone. It is the same phone I've had for 3 years now.
Best Answer02-09-2019 00:33 - edited 02-13-2019 01:24
@abgmann it should not have been necessary to remove the Charge 2. Weight and food has nothing to do with the tracker
02-12-2019
13:48
05:29
YojanaFitbit
02-12-2019
13:48
05:29
YojanaFitbit
I didn't remove the tracker. I reloaded the app. The weight calculations were still wrong. So I took out the .2 and put in a pound less. It is off by a pound. The tracker does keep track of the calories out. The app interacts with those. The app was screwed up, confused, I don't know. Now it seems to be adding correctly.
Sad News For Meghan Markle And Prince Harry
