05-02-2020
12:03
09:49
05-02-2020
12:03
09:49
Like many customers of fitbit I have faced the disappointment of first my Charge 2 screen cracking for no apparent reason, and even worse the screen completely falling off and breaking into 3 pieces when I was taking my running top off over my wrist. This has rendered the product useless as the screen can not be fitted back on and made to work. For a product costing over £100 at time of purchase this should just not happen - especially when it was a replacement itself for a previous fitbit that was caught in a splash of water and immediately stopped working. As my purchase was over 2 years ago I was offered what appears to be a standard 25% discount on the fitbit.com website for a replacement product which I have not taken up as (1) the market price is lower than the fitbit site and there would only have been a few percent of a discount in reality, and (2) I had for some time been disappointed in the inaccuracy of measurement of some of the key features that are supposed to differentiate and justify fitbit's higher prices. Namely, the heart monitor was invariably wrong whenever I tested against my own pulse manually, and also the sleep recorder, usually had to be edited to make sense. As a result I am going to try one of the competing products which are a lower price but with same functionality. I will be disappointed to discontinue having a fitbit as the app itself is good - it's a shame the products dont seem to be sufficiently reliable for the price charged
05-12-2020 12:03
05-12-2020 12:03
@Wiliemo Thanks for stopping by!
Sorry for the delay in my reply and to hear about your damaged Charge 2 screen. Support does follow the guidelines listed in the warranty so if your device is outside the warranty period they won't be able to replace it. This is why they offer a discount to help customers in this situation. Still thank you for sharing your feedback.
Regarding the heart rate reading accuracy I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Finally about the sleep detection, your device will start recording sleep after it detects an hour of inactivity. If you have a light sleep or move too much then this may difficult your sleep detection. Additionally you can try wearing your device on your non dominant hand to decrease the amount of movement it is subjected to. Finally you can restart your device. You can also manually log your sleep time. You can read more about sleep detection here.
Regardless of the device you choose I hope you keep up the good habits you have and reach your fitness goals.
I'll be around.
05-12-2020 14:08
05-12-2020 14:08
05-18-2020 06:15
05-18-2020 06:15
