02-28-2020
22:39
10:14
02-28-2020
22:39
10:14
Hello! My Charge 2 keeps disconnecting with my phone's GPS during my runs (It has been fine for months and only started acting up now). I've restarted my Bluetooth, phone, and Fitbit but nothing seems to have worked 😕
I've approached the Fitbit service center in Singapore to get a replacement but they do not have any Charge 2 models available
is there anything I can do to fix my Fitbit? 😞
Cheers!
03-01-2020
09:14
06:19
03-01-2020
09:14
06:19
@ParallelFell Welcome! Thanks for being part of our Community! Sorry for the delay in my reply.
Let me help you with your Charge 2 not staying connected to your phone's GPS. Which phone are you using? Is it compatible? You can try refreshing the link between your phone and your tracker by doing the following:
Let me know how it goes.
03-01-2020
09:14
06:19
03-01-2020
09:14
06:19
03-03-2020 18:57
03-03-2020 18:57
Hello!
Thank you for your help! I've changed the settings on my phone to allow Fitbit to run in the background (it was turned off due to power saving). My Fitbit works fine now.
Thank You!
Best Answer03-05-2020 08:39
03-05-2020 08:39
@ParallelFell thank you for the update and sorry for the delay in mine.
Really happy to hear that you were able to solve the issue following my previous instructions and thank you for sharing what was the issue as this may help other members in the same situation.
