02-01-2018
04:46
18:54
02-01-2018
04:46
18:54
I am very frustrated all I see on my charge is calls coming in I cannot see my text messages on my iPhone 8 and I do not know how to get this to work I have tried everything
02-01-2018 05:41 - edited 03-03-2024 03:28
It's nice to see you around the forums @SunsetRunner! Please make sure your tracker is not currently on the "Do Not Disturb" mode by pressing down the button on the side for 2 seconds, a vibration and a message will let you know if "Do Not Disturb" has been turned on or off.
If you have any other tracker or if you have already tried this, please go to your phone settings and make sure "Do Not Disturb" is disabled, then go to Notifications > Fitbit and make sure the following is enabled:
If you make sure about that, but the text notifications are still not working, I'd like to suggest you to please follow these steps in order to reset Notifications on your phone and tracker:
- Go to the Bluetooth settings on your phone and tap on Charge 2. Then tap on Forget this Device.
- Force-close the Fitbit app by double tapping the home button on your phone and swiping up the app.
- Open the app again and tap on Account > Charge 2 > Notifications. You will receive the following Pop-up:
- Then, once you tap on Set Up, the app will begin setting up your tracker with the Bluetooth on your phone, which will prompt the next pop-up
- Tap on Pair.
Once the process is finished you can go back and tap on Account > Charge 2 > Notifications and select the ones you'd like to receive.
I hope this can be helpful, give it a try and keep me posted in case you need anything else! ![]()
- Tap on Pair.
02-01-2018 07:50
02-01-2018 07:50
Best Answer05-17-2019 02:47
05-17-2019 02:47
I was getting call notifications. But not messages I have followed thee. Steps and now can’t get either. ,, any ideas?
Best Answer10-15-2019 15:33
10-15-2019 15:33
Nothing seems to work😒
Best Answer01-10-2020 11:09
01-10-2020 11:09
Just went through live chat to solve this issue only to have them tell me it's an issue they are aware of and there is no estimated time for the resolution. I have always been a huge FitBit fan, but for the money spent on this latest one, I will return it and buy something that is reliable with better customer service. Honestly, FitBit should be ashamed that is their answer to the notifications being an issue rather than trying to find a real resolution. Not even an apology....sad.
Best Answer04-10-2020 08:58
04-10-2020 08:58
I finally got my text notifications working on my Fitbit versa 2. IPhone Setting, notifications, messages . Notification Center has to be checked. After trying everything else that fixed mine....
Best Answer06-07-2020 12:36
06-07-2020 12:36
I just had this problem with my iPhone 8 today. I went through every possible step I could find to try and fix the issue. On my iPhone, I ended up going into settings, notifications, messages and turning the toggle on for “show previews”. I had it turned off initially and now that I turned it on, I’m getting texts to my Fitbit.
08-03-2020 15:38
08-03-2020 15:38
Finally, something that works. I spoke to Fitbit for over an hour one day troubleshooting and nothing worked. Most of the suggestions were obvious about notifications being on, or resetting the devices. I thought it was my device so I bought a new one. Got the new one and it had the same problem. I am so glad I found your solution. Thank you.
01-14-2021 08:55
01-14-2021 08:55
yep this just worked for me
Best Answer10-10-2021 22:14
10-10-2021 22:14
i found that if either "show previews" or "when unlocked" is selected, the versa 2 will vibrate and show text previews. thanks so much this fixed my problem!!!
