05-25-2020
21:24
09:40
05-25-2020
21:24
09:40
I used to be able to get a map of my activity but it doesnt work now. I have it set in the Fitbit app to use GPS for walks and bike rides. I have it set on my Samsung Galaxy S9 to allow the Fitbit app to access location at all times. There is no phone icon on my Fitbit Charge 2. I have good bluetooth communication between my Fitbit and my phone. Super frustrated!
05-26-2020 13:02
05-26-2020 13:02
Check your settings for the exercise and make sure that the GPS is enabled. You should see an icon on the tracker with the word connecting.
Best Answer05-26-2020 15:49 - edited 05-26-2020 21:51
Yes the exercise is set to use GPS and GPS is activated on the phone.
Strava on my phone works fine for tracking the route. I just want it to
work on my Fitbit!
Best Answer05-29-2020 10:35
05-29-2020 10:35
Customer service at Fitbit solved the problem. I had to unpair the device and remove it from my profile and then re-pair it and add it back in.
