02-08-2019
13:32
11:22
02-08-2019
13:32
11:22
After changing my Fitbit now has grey vertical lines goin down it .... I have tried to restart it a few times but they are still there ... I have tried to clear data as well .... the battery charge now seems to be goin down really quick .... only got this in Oct on pre-order so still under warranty .... anyone have any other suggestions? Thanks
Update: Now it’s gone red hot at the back and been vibrating loads and now the screen has gone off?? No idea what’s happening ....
07-10-2019 23:36
07-10-2019 23:36
My Fitbit has a grey lines too , i just got it as a gift 2 months ago please help
Best Answer07-11-2019 14:21
07-11-2019 14:21
Welcome on board @AlanlanA and @Shelle1979! Thanks for troubleshooting your Charge 3 prior to contacting us.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this. Please keep an eye on your inbox for updates on your case. ![]()
Welcome to the Community Forums @Nige101! Thanks for following the tips and recommendations provided above.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if you have any questions present.
Best Answer07-11-2019 14:24
07-11-2019 14:24
I can not fault the service I have received at all! Thankyou 😀
07-14-2019 11:32
07-14-2019 11:32
Hi,
I have exactly the same problem described in this post and I've tried the reset method and it did not work.
Beyond just having the grey lines, the screen is sometimes not responsive and I cannot swipe it to the sides
This problem appeared today in the morning and with time the grey color/lines got brighter and wider
I would highly appreciate help with it
Thank you very much for your time and effort!
Best Answer07-14-2019 11:41
07-14-2019 11:41
07-14-2019 12:16
07-14-2019 12:16
Completed the upgrade this afternoon and now my screen is showing grey lines.
After reading comments I have restarted 3 times but the lines are still there. Had the Charge 3 approx 4 months.
Unable to upload photo.
Best Answer07-21-2019 09:04
07-21-2019 09:04
The problem got worse... the grey lines got bigger and brighter 😞
Rebooting several times did not solve the issue
Any suggestions?
Best Answer07-21-2019 09:22
07-21-2019 09:22
I ended up contacting customer services, as my Charge 3 is still in warranty they are sending a replacement.
Best Answer07-21-2019 09:23
07-21-2019 09:23
08-05-2019 09:35
08-05-2019 09:35
Same here there are grey lines going down across the screen of my charge 3, the battery doesn't seem to go down too quick which is good but I am wondering what might of happened
Best Answer08-19-2019 14:57
08-19-2019 14:57
Hi I too have started to get grey vertical lines appear on my charge 3 watch. I have tried resetting the watch and changing the clock face but it hasn’t solved the issue. Please can you advise on how to resolve this. Thanks
Best Answer08-19-2019 14:59
08-19-2019 14:59
Best Answer08-19-2019 21:03
08-19-2019 21:03
I am having the same gray lines, tryed to reset but no luck... Help please
Best Answer08-19-2019 21:13
08-19-2019 21:13
Hi,
I have been having the same issue. Started with not being able to read the clock race during the day on my charge 3 that I received this past June for fathers day.. Now certain parts of the screen isn't readable even during the evening. I tried changing the clock race. I tried reseting the device. I even tried rebooting the device. It's almost like the screen is burning out.
Best Answer08-23-2019 07:23
08-23-2019 07:23
Good morning,
My Fitbit has the grey lines starting this morning after charging. My boyfriend bought me this in June of this year. I have tried the reset and it is not working. Any other suggestions?
Thank you,
Gillian
Best Answer08-23-2019 10:09
08-23-2019 10:09
Best Answer08-23-2019 12:50
08-23-2019 12:50
Best Answer08-23-2019 15:14
08-23-2019 15:14
08-23-2019 22:31
08-23-2019 22:31
I'm also getting the gray lines on screen of my Charge 3, it's less than a year old. Also seeing sporadic issues navigating the menus and times stopping without touching the device.
I've reset the device multiple times and changed the clock face as well and the issues seem to be increasing and becoming worse as time passes.
Any help would be appreciated.
Thanks
Best Answer08-24-2019 06:14
08-24-2019 06:14
