02-08-2019
13:32
11:22
02-08-2019
13:32
11:22
After changing my Fitbit now has grey vertical lines goin down it .... I have tried to restart it a few times but they are still there ... I have tried to clear data as well .... the battery charge now seems to be goin down really quick .... only got this in Oct on pre-order so still under warranty .... anyone have any other suggestions? Thanks
Update: Now it’s gone red hot at the back and been vibrating loads and now the screen has gone off?? No idea what’s happening ....
08-31-2019 11:56
08-31-2019 11:56
Hi there!
I’ve got the grey lines going horizontally across my screen too!! I’ve tried the restart whilst it’s on the charger and I also tried changing the clock face via the app as was suggested by someone in the community but no luck! I only got it in February so it’s still under warranty.. Anyone got any further suggestions for me to try?? Help please 😞 😞
Best Answer08-31-2019 13:12
08-31-2019 13:12
Contact Fitbit they will send you a replacement right away:) I got mine last week!
08-31-2019 14:18
08-31-2019 14:18
I started having the vertical line issues with my Charge 3, have changed the clock face, have restarted, have done a deep restart, all to no avail. Is there a fix for this?????
Best Answer08-31-2019 17:00
08-31-2019 17:00
You will have to contact Fitbit. They should be able to replace it for you. I read an article that issues are due to the recent Fitbit update.
Best Answer08-31-2019 17:02
08-31-2019 17:02
09-01-2019 00:35
09-01-2019 00:35
Best Answer09-01-2019 00:37
09-01-2019 00:37
Thanks so much for your reply! I can’t seem to find a contact for Fitbit directly- how did you get in touch with them?
Best Answer09-01-2019 03:21
09-01-2019 03:21
09-01-2019 07:09
09-01-2019 07:09
Best Answer09-06-2019 20:38
09-06-2019 20:38
What is “the button”?
Best Answer09-09-2019 12:26
09-09-2019 12:26
Hi there
If you have no luck with the suggestions email FitBit. They were super supportive and replied very quick! After emailing them they sent their suggestions to help, unfortunately this didn’t help me but seemed to have helped others. However they quickly replied with a replacement offer! My replacement is being delivered in a few days!
Really good service:)
Best Answer09-09-2019 12:57
09-09-2019 12:57
Best Answer09-20-2019 07:40
09-20-2019 07:40
I’ve got the same problem also a Christmas present. Restart hasn’t helped. I called support but they put me on hold then got disconnected and they didn’t call back. The retailer refused to exchange as they say the screen isn’t covered by warranty??? Is there a fix?
Best Answer09-21-2019 08:41
09-21-2019 08:41
Best Answer10-03-2019 18:04
10-03-2019 18:04
I am having the same problem with my charge 3 and have tried everything to fix it but nothing works. I was on line with someone and was given a case number but as they didn’t help much at all. They just had me do the same thing over and over with the same results. What do I do now? How do I get rid of the grey lines and back to the way it should be. This Fitbit is only 8 or 9 months old.
Best Answer10-03-2019 18:39
10-03-2019 18:39
That is annoying. Call Fitbit and they will replace it for you. It is covered under warranty. Customer service is usually very quick.
Best Answer10-04-2019 00:38
10-04-2019 00:38
Best Answer10-04-2019 05:17
10-04-2019 05:17
Best Answer10-04-2019 05:38
10-04-2019 05:38
Best Answer10-04-2019 08:03
10-04-2019 08:03
