04-24-2017
02:43
20:15
04-24-2017
02:43
20:15
I have had a half filled bar in my charge hr and its driving me mad!! I've rebooted my tracker at least 20 times. Reinstalled the app many times as well and tried unpairing the device as well. But the bar keeps coming back. My tracker also shows the wrong time, when the bar briefly goes. I've had this since Wednesday and I obviously can't sync. I've had my Fitbit since august last year. I'd be grateful for any other advice
04-24-2017 02:55
04-24-2017 02:55
I have had this exact same problem ...
i have half a coloured in bar - this is so annoying !
happend to me on Wednesday also
Best Answer04-24-2017 02:55
04-24-2017 02:55
Best Answer04-24-2017 03:22
04-24-2017 03:22
That's interesting. Maybe an update malfunction.well I've emailed customer support, waiting on response
Best Answer05-13-2017 13:57
05-13-2017 13:57
Does anyone have a sulution to this problem yet?
Best Answer05-14-2017 05:44
05-14-2017 05:44
We want to know the solution.
Best Answer05-14-2017 17:57
05-14-2017 17:57
Best Answer05-14-2017 18:40
05-14-2017 18:40
I also have a half filled bar on my fitbit? What is the solution?
Best Answer05-15-2017 01:32
05-15-2017 01:32
After a few back and forth emails to customer service, they replaced my Fitbit. I have to say customer service were excellent. They did give me advice on how to fix it, but these didn't work.
Best Answer05-15-2017 03:54
05-15-2017 03:54
Best Answer09-03-2017 16:59
09-03-2017 16:59
I had the same problem. I then noticed that the band on the charge HR had a little separation. I pushed it together applied super glue to hold it together it now works.
Best Answer11-01-2017 12:33
11-01-2017 12:33
Hi,
happened to me today: Stuck in half bar after trying to update to the new firmware from my phone. Reset didn't help.
I connected the tracker to the USB port of my Mac and downloaded the Fitbit app for Mac. It was able to find the tracker over USB (not Bluetooth) then proceeded to install the update. After a few minutes, the update went through and now my tracker works fine.
If anyone else is stuck in half bar mode, try connecting the tracker to your computer over USB and use the fitbit application for your computer, _not_ the phone to update.
Hope this helps,
Constantin
11-01-2017 16:05
11-01-2017 16:05
I just had this happen to me today while applying an update to my Charge HR through the iPhone app. Update progress bar made it half way then stopped and would not respond to any input from the button. Ultimately I got it to finish the update by going into my Bluetooth settings on the iPhone and telling it to Forget the Device. I know, it doesn't make any sense but as soon as I did that the update bar started moving again and finished the install. Hope this helps somebody else!
11-01-2017 20:52
11-01-2017 20:52
This is exactly what happened to me yesterday. I took your advice and it worked. Thank you
Best Answer01-26-2018 18:07
01-26-2018 18:07
Just did this and it worked!!!!!
Best Answer02-03-2018 18:31
02-03-2018 18:31
I tried all the fixes identified via forums, none of which worked. I then contact customer service, tried one of their fixes, which didn't work, tried to do a factory reset - fitbit would not even reset. I was then told that my fitbit is out of warranty and was offered a 25% discount on a new tracker. Given that this half bar of death problem seems to span several years I do not trust than any new model will not have the same design problem. I would suggest buying a different brand as I will be.
Best Answer05-16-2019 15:00
05-16-2019 15:00
I genuinely have no idea how this works but it did!! Thanks
Best Answer05-31-2019 16:10
05-31-2019 16:10
WORKED! Thanks for taking the time.
Best Answer12-15-2019 11:07
12-15-2019 11:07
How did you do that using USB don't you need a wireless dongle thing?
