Heart Rate shows in App when not wearing Charge 2
I have found that there is Heart Rate data logged into the App for 4 hours while playing golf and the Charge 2 is in my golf bag. I don’t understand how there can be any HR data when not wearing the Charge 2.  This has happened two weeks in a row with the HR data is up in the 120-130 range which is not normal.
Can anyone explain this oddity???
1 REPLY 1
@Adanac55, it's great to see that you've visited the Fitbit Community!
Let me help you with your heart rate readings on your Charge 2. This could be due to the settings you are using or by it being against your leg but still is odd. I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on but use the Auto option, save and sync again. Also check these tips to improve the heart rate reading on your device.
Let me know how it goes.
Alvaro | Community Moderator
