Heart rate and active zone minutes not working since 26.10.2021
My heart rate and zone minutes are not working. The heart rate effects my sleep tracking as well. I can see how long I sleep for but not in what kind of sleep I was in. The fitbit tracks activity but when looking in the zone minutes it says 0. I hope this issue will be fixed soon these are one if the main features that effect other parts of the app too.
3 REPLIES 3
Since 26.10.2021 ?
If you recently got a firmware update, I think your Charge 3 might have just switched from Active Minutes to Active Zone Minutes which require more intensity to earn.  See What are Active Zone Minutes or active minutes on my Fitbit device?
This may be the case however I believe my heart hasn't stopped since then. This has to be a bug of some sort. My active zone minutes can only be tracked if my heart rate is tracked. At the moment it does neither.
A happy accident gave me the solution. The update seems to have changed some peoples settings. My heart rate was turned off. This worked for some unfortunately not for all. An update really should change such fundamental settings and if it does this seems like a simple tip to give to users.
