07-26-2018
15:12
18:22
07-26-2018
15:12
18:22
My heart rate monitor on charge 2 has stopped working. I’ve tried resetting (holding side button down whilst charging) but that has not helped. Any suggestions on what else I could do?
07-26-2018 16:28
07-26-2018 16:28
Try that Restart several times before giving up. If it still doesn't work, contact Customer Support.
07-26-2018 16:28
07-26-2018 16:28
07-26-2018 22:00
07-26-2018 22:00
Ok, will do. Cheers
Best Answer07-27-2018 09:23
07-27-2018 09:23
Hey @Harvey052000, welcome aboard! I'd like to help you out with this. So could you please tell me, on your Charge 2, instead of your BPM, are you getting this "--"? If so, beside the restart that my friend @SunsetRunner suggested, I'd like you to try the following:
- Try changing the setting (either Auto to On or On to Auto) and then syncing your tracker. The change won't take effect until you sync.
Let us know how it goes!
Best Answer07-27-2018 10:46
07-27-2018 10:46
Best Answer07-28-2018 12:39
07-28-2018 12:39
Brilliant customer service and solution found within a couple of days.
Replies were quick and resulted in a replacement being sent out. Very impressed!!!
07-30-2018 06:23
07-30-2018 06:23
Hey @Harvey052000, thanks for the update! I appreciate the time you have taken to follow the instructions I posted above and also, for taking the time to contact our Support team! They are simply the best! And it's great to know that they have processed a replacement for you to get you back on track.
If you have further questions or comments, let me know!
Best Answer05-12-2019 23:47
05-12-2019 23:47
Hi, I have tried to resync as you suggest and it still doesn’t work?
Best Answer10-07-2020 02:10
10-07-2020 02:10
If you are resetting the chest strap, turn the battery over, and reinsert it with the negative (–) side facing up. Then wait three seconds to dissipate the charge in the battery and reset the heart rate chest strap.
