07-10-2018
04:07
18:22
07-10-2018
04:07
18:22
Hello I use at the gym an ergo hand crank and have the Charge 2 on my wrist to monitor the heart rate. The charge 2 indicates my average heart rate is 111 but that is a lie as my actual average heart rate using a strap is 125. It is the worst thing I have ever tried. How do I return the charge to for a refund? I purchased the product from a retailer in Australia.
07-10-2018 04:10
07-10-2018 04:10
I also forgot to say, when I have the charge 2 on my wrist over night, to my surprise I have not 50 steps when I wake in the morning. Have not got out of bed all night .... it is not usable.
Best Answer07-10-2018 04:45 - edited 07-10-2018 04:46
Welcome to the Fitbit Community @csayers069! As with all heart-rate tracking technology, whether a chest strap or a wrist-based sensor, accuracy is affected by personal physiology, location of wear, and type of movement.
When you’re not exercising, wear your device a finger’s width below your wrist bone. Fitbit’s PurePulse heart-rate tracking system is designed to be most accurate when the device is worn on the top of your wrist.
For improved heart-rate accuracy keep these tips in mind:
Note that if you remove your device but it keeps moving, for example if you put it in a pocket or backpack, the device may display an incorrect heart-rate reading. To prevent this issue, turn off heart-rate tracking when the device is not in use. See below for instructions.
About the 50 steps you had upon waking up, this is due to Fitbit trackers may register movements or restlessness as steps when you're wearing it while you sleep. The number of steps typically measured during these periods is minimal, and should not offset your overall fitness progress. Any steps taken to and from other rooms during the night will also be tracked.
Keep in mind that it's possible to get different readings if the trackers are worn in different locations (dominant vs non-dominant wrist). I'd recommend reviewing the accuracy information provided in this post.
In regards to the return inquiry, since you've purchased from a retailer, you'll need to return your product directly to the retailer and follow their return and refund process. This information is generally printed on your receipt, though you may also find it on the retailer's website. Note that we're unable to influence retailer policies.
If there's any questions present, let me know.
Best Answer07-17-2019 11:01
07-17-2019 11:01
So basically, many forms of exercise where one who bought their fitbit for measuring their heart rate are considered inaccurate.
I use mine whine backpacking to use my heart rate for my pace. Very inaccurate for the HR compared to checking it with my finger and carotid artery. Off by 10-15%.
I tried rotating the watch around 180 degrees. Same. Tried moving the watch slightly up from the wrist location. Same. Useless!
