08-24-2017 08:15 - last edited on 09-09-2020 09:26 by MatthewFitbit
My charge2 heart rate is 67 during hard exercise and i can feel my heart beating fast?!
Realy i have concerns about charge2 heart rate and how app calculates burned calories?
12-27-2018 01:43
12-27-2018 01:43
01-22-2019 07:07
01-22-2019 07:07
01-27-2019 15:16
01-27-2019 15:16
Fit bit trackers suck. Don’t waste your money. Heart rate is inaccurate and useless, when it actually tries to show a reading, and skews every other reading. Constantly zeros out and reads 179 bpm when I’m in bed watching tv. Showed 2000 steps one day and then showed 120 active minutes. WTF! Not to mention the inaccurate sleep readings. And try getting someone that speaks English and doesn’t yell at you when calling “customer support”. What a piece of junk. Tossing this in the trash.
08-27-2019 17:29
08-27-2019 17:29
The whole Fitbit is almost all fake news like Cnn . I have a Charge 2 and very inaccurate heart rates when exercising . I have tried loose to tight and different positions . I can go up stairs and get no flights but when I am plowing snow in my truck and steering with my left hand and bouncing from the bumps it shows high heart rates that aren't happening and it thinks I am walking and getting lots of steps and had as many as 100 flights of stairs going up and down hills when plowing and even if you do get some real readings once in a while the graphs for your heart rate do not have enough lines to see where your heart rate is and the graph lines are always in different place . Why can't they make good graphs with enough lines in the grids and have it be consistent every day and not just 1 at the top , 1 at the bottom and 1 in the middle and you have to guess . I am 65 and had an ablation for afib and it has been cured and have been working on building my heart back up . I did 1000 toe touches this morning in 21min 40sec. My real heart rate when checking my pulse for 1 minute was 138 , the fitbit was 78 . I can't get accurate heart rates even with a fast walk . Junk !
08-28-2019 01:51 - last edited on 10-20-2021 06:09 by JuanJoFitbit
11-03-2020 08:21
11-03-2020 08:21
I’ve just about given up on Fitbit! I’m in my 3rd one! Original Charge crapped out after a year. Bought the Charge 3 SE less than a year ago and the screen gave out within 6-7 months! I didn’t feel like haggling with customer service so I just bought a new Charge 4. What a mistake!
The HR is all over the place! Ironically, mine is far too high when doing light work. For giggles, I decided to lay in bed and just pump my arm 250 times. Well, it had my HR at 170! I’m 52 and trust me, I’d know it if my HR was 170! I put in a pulse oxygen meter and low and behold, my pulse was 95! Big difference from 170. Worse, Fitbit had it remaining in the 140 range for a solid 2 minutes. Finger monitor had it back to 72 inside of a minute.
These are only a few of my issues/problems with Fitbit. Sorry but I think it’s time for me to invest in an Apple Watch (between my 3 purchases + bands, I could have bought one already).
Three strikes and Fitbit is OUT!
12-29-2020 01:22
12-29-2020 01:22
Yeah. Agreed.I definitely won't spend more than a couple of euros or dollar in those watches.
07-12-2021 20:01
07-12-2021 20:01
My bike has a heart rate monitor and when I had a Fitbit versa they were always in sync. This charge 2 is always off or just doesn’t register a 150bpm avg heart rate for 40 of a 50min workout. It’s clean and fits perfectly on my wrist. It’s just not accurate.
08-13-2022 14:52
08-13-2022 14:52
Finally someone noticed that Fitbits can not tell accurate heart rate in exercise mode! 🤬 once I exit exercise mode, then, and only THEN does it tell my accurate heart rate. Sucks!
02-06-2023 07:08
02-06-2023 07:08
I can literally feel my heart rate different from the fitbit's reading. I clean the thing every day. dont give me this crap
04-18-2023 05:04
04-18-2023 05:04
Same with my sense
04-18-2023 05:05
04-18-2023 05:05
Mine is totally fine ..clean, making contact. It also stopped giving my detailed sleep results. The thing never moves and it used to work fine
04-18-2023 08:38
04-18-2023 08:38
In fact I moved on the a cheaper brand . For less than 20 $ I found a simple but effective way to monitor my heart rate by adding the thoracic belt.
This is the best way to get proper measurement
