04-18-2020
03:53
16:20
04-18-2020
03:53
16:20
Hi,
I received my C4 today to replace my C3 - charged it, installed it, and it automatically performed a firmware upgrade.
All seems to work, except the heart-rate is no displaying; greyed out and display '--'. in the app (iphone), I have heart-rate data up to the switch from C3 to C4. I did a reboot of the C4 and iphone etc ... no avail.
I assume the C4 has a broken heart-rate sensor ? Can some-one confirm this ?
Chris
Belgium
04-18-2020 04:18 - edited 04-18-2020 04:28
The current heart rate is not shown also on Android device (Samsung Galaxy Note10+). When I open the weekly statistic for heart rate I see all values.
04-18-2020 05:27
04-18-2020 05:27
Is their a heart rate displayed on your watch?
Is the heart turned on?
04-18-2020 05:56
04-18-2020 05:56
04-18-2020 06:01
04-18-2020 06:01
I've seen many reports of heart getting mysteriously turned off, that is why I asked.
OK your app will tell you when the last time the tracker has synced.
04-18-2020 08:22
04-18-2020 08:22
04-18-2020 09:57
04-18-2020 09:57
Have you tried rebooting both your Fitbit and your Phone and last resort deleting and setting up as new again.
04-18-2020 10:58
04-18-2020 10:58
04-19-2020
02:14
06:26
JuanJoFitbit
04-19-2020
02:14
06:26
JuanJoFitbit
Today (Sunday 19/04 - European time) I received a new firmware update for the Charge 4 (48.200018 2.46), so I hoped this would solve the issue ... unfortunately it did not.
I have completely reinstalled, rebooted everything: iPhone and charge4 ; same problem; no heartbeat or steps displayed/recorded on the charge4 - the menu's and time ... all works - I assume it's the sensor-subsystem which is not working.
I removed it from my app and re-added the charge 4, which works great ! I am long time user of fitbit since the first days (the usb-stick design) ... and this is the first time I have a problem.
I will have to return it
CORRECTION:
I removed it from my app and re-added the charge 3, which works great ! I am long time user of fitbit since the first days (the usb-stick design) ... and this is the first time I have a problem.
Chris
Belgium
Moderator edit: merged reply
04-19-2020 04:24
04-19-2020 04:24
You can still tap on the greyed-out heart-rate and will see the heart-rate statistics.
But you are right, the live-heart rate in the dashboard does not work.
Seems to be a problem of the App or the Charge4 or a combination of it.
When I use another tracker (e.g. Inspire HR) the dashboard shows the live-heart-rate again.
Going back to the Charge4 it's gone.
For me it's sufficient that I can access the heart-rate statistics, as I can see the live-heart-rate on the Charge4.
But let's hope fitbit solves this soon.
04-19-2020 04:40
04-19-2020 04:40
I have the exact same problem. I can see the HR on the C4 but in the app it is grayed out. No statistics when I click on it as well, only says "no measurements".
Waiting for the new firmware update and if it does not help Im going to have to return it tomorrow..
04-19-2020 04:53
04-19-2020 04:53
04-19-2020 05:54
04-19-2020 05:54
If the heart-rate is also not showing on the C4, have you switched heart-measurement off?
If you swipe to the left, you can change this in the settings.
04-19-2020 07:44
04-19-2020 07:44
Chris I returned my C4 Friday and got a new C4 yesterday. Same issue 😞
Hope a software update will solve this problem.
04-19-2020 07:55
04-19-2020 07:55
04-19-2020 08:00
04-19-2020 08:00
04-19-2020 08:38
04-19-2020 08:38
04-19-2020 17:39
04-19-2020 17:39
Hi everyone. It's always great to see you in the forums.
Thanks for bringing this to my attention, as well for the steps tried prior posting. This should not be happening and to work on this together I'd recommend to try to the following steps:
If the heart rate or any other stat, such as your steps are still not displayed on your tracker or the Fitbit app, let me know so I can further investigate on my end.
Keep me posted.
04-19-2020 23:21
04-19-2020 23:21
No result here 😞
Still no heartrate on the phone app (greyed-out)
04-19-2020 23:33
04-19-2020 23:33
I am thinking of returning this C4 and go for an other brand.
How can a company release a product without testing it propperly?
Look at all these issues here 😮
