02-20-2019
12:36
17:14
02-20-2019
12:36
17:14
I have noticed today that my heart rate has not been tracked at all. I have it set to Auto detect in the app but no data at all. Also my sleep for last night looks like it has not tracked properly. On the tracker itself the two dashes on the heart rate display aren't even flashing. Any suggestions? Thanks
02-21-2019 11:24
02-21-2019 11:24
@ClareFarquhar Welcome to the Fitbit Community! I hope you're doing well! Sorry to hear that your Charge 2 isn't recording your heart rate. I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Also check these tips to improve the heart rate reading on your device. Also turn off the heart rate sensor, save and sync then turn it to auto and save and sync again.
Regarding the sleep, what are you seeing that is incorrect? Is time missing from the sleep log or recorded at an incorrect time.
I look forward to your reply!
Best Answer02-21-2019 15:31
02-21-2019 15:31
Hi,
I have already tried cleaning, restarting and turning heart rate monitoring off and back on. The problem seems to be that the green lights on the back of the tracker are no longer flashing, just a constant green light which now seem to be fading.
The problem with the sleep tracking is probably related as it is not detecting sleep stages . Is there anything else that I can try?
Thanks
Best Answer02-21-2019 18:06
02-21-2019 18:06
I have been having the same issue since February 2nd. I’ve done all the troubleshooting and had no luck. It’s becoming concerning as I am missing valuable data for my workouts.
02-23-2019 00:06
02-23-2019 00:06
This is becoming frustrating and no further reply from Fitbit. I am tempted to look at other brands but my son just got a kids Fitbit so we can compete and it would be a shame if we were using different trackers.
02-23-2019 09:33
02-23-2019 09:33
I did yet another reset last night and this time it seems to have worked. Maybe try again? I wish you luck. I know how frustrating this is. I am hoping my HR tracking does not stop again.
02-24-2019 01:42
02-24-2019 01:42
Thanks, after reading your suggestion I did try again last night and got very excited when the green lights started flashing. However after charging overnight it is again not working. I'm starting to wonder if it's my tracker or the firmware as I have seen a few posts with similar issues over the last few days.
02-24-2019 03:30
02-24-2019 03:30
Similar issue suddenly no heart rate tradings. Cleaned rebooted and also turned it off re synced and still not working? Firmware glitch? Green lights are flashing.
03-04-2019 11:42 - edited 03-04-2019 11:45
@KPatc Welcome to the Fitbit Community! It's great to have you here!
Sorry to hear that your Versa isn't detecting your heart rate and thank you for following the suggestions in this thread. Since the issue persist please let our support team know so they can further assist you. @ClareFarquhar you will get an email from them. @KPatc is your heart rate still working fine? @jaumealaska I noticed that you already have a ticket with them so I wanted to know if they were able to help you?
Keep me posted.
Best Answer03-04-2019 14:30
03-04-2019 14:30
Same problem here! I have reset several times and cleaned my tracker. Still no heart rate. My green lights on the back are blinking.
Best Answer03-04-2019 14:37
03-04-2019 14:37
Best Answer03-04-2019 14:38
03-04-2019 14:38
Best Answer03-07-2019 13:08
03-07-2019 13:08
Hi,
I don't want to tempt fate but my Charge 2 appears to be working again. I did another few resets late at night and eventually it started working again. Fingers crossed it lasts.
Thanks
Clare
