06-16-2020
10:50
09:24
06-16-2020
10:50
09:24
My Charge2 has a problem with sensors. The two little green lights’ sensors that normally are flashing, it turn out that they are lit up like a flood light, literally. This in turn drains the battery. It all started 2 days ago and today, somehow it works fine but at night it happens again. I use this for about 2 and a half years. By the ways, I try all the things that Fitbit help said (restart the Charge2, clean the device, charging the device with a USB port from a computer or a UL-certified outlet into the wall, turn off unused feature) Any answers?
06-17-2020
19:17
05:37
06-17-2020
19:17
05:37
Hi @Ery.kras, welcome to the Community Forums!
Thanks for bringing this to our attention and for the details that were shared in your post, your effort trying some troubleshooting steps before to posting over here is also appreciated. To resolve the heart rate issue, I recommend you to try our restart process following the next steps:
Once the heart rate sensors start working normally, the battery drain issue should be corrected. Otherwise, please contact me back to further investigate.
Keep me posted.
Best Answer07-28-2020 20:16
07-28-2020 20:16
I have restarted the Fitbit multiple times and the heart rate lights are still on. I have even turn heart rate OFF under my settings. As a result, the battery is inly lasting 30 minutes or so. Should I remove the Fitbit charger 2 and add it again?
any help would be appreciated it
thanks
agustina
12:08
05:37
07-29-2020
12:08
05:37
Welcome aboard @Agustinap.
First, I'd like to appreciate your effort troubleshooting your Charge 2 before posting over here. If you haven't already done so, I recommend you to try the steps that are specified on: Why don't I see my heart rate on my Fitbit device? to troubleshoot the heart rate sensors of your device.
After following the above information, please check this help article for tips and recommendations for battery life usage.
I'll be here if further assistance is needed.
Best Answer07-29-2020 16:13
07-29-2020 16:13
