01-20-2018
11:09
18:54
01-20-2018
11:09
18:54
My charge 2 actually shows heart rate when I’m not even wearing it.
01-23-2018 05:25
01-23-2018 05:25
Hey @SueMomma622, it is great to see new members around! I'd like you to confirm with me if you have not been wearing your tracker for at least a minute before checking your heart rate.
In the meantime, please try the following:
1. Switch HR setting to off and sync.
2. Switch HR setting to Auto and sync.
3. Wait at least 60 seconds before checking heart rate again
4. Restart your Charge 2
Let me know how it goes!
01-23-2018 05:25
01-23-2018 05:25
01-23-2018 13:11
01-23-2018 13:11
01-24-2018 05:06
01-24-2018 05:06
Thanks for your response! And for taking the time to try what I suggested to fix this issue @SueMomma622. Since your Charge 2 still tracking your heart rate while you are not wearing it, I urge you to take a look at your inbox so you can get further assistance.
01-28-2018 04:43
01-28-2018 04:43
Hello. I had tried this and it did not work. You have sent me a replacement and it is working perfectly. My old Charge 2, after more than 24 hours of not wearing, is still showing a heart rate. Thank you for caring as you do. Your customer service is above any I have ever had to deal with. Thank you again.
01-28-2018 05:31
01-28-2018 05:31
Mine records high calories burnt when not wearing!
01-31-2018 04:21
01-31-2018 04:21
Hey @SueMomma622, thanks for the update! Sounds pretty awesome that our Support team has helped you out with this and have sent you a replacement to get you back on track.
@Fee-Fee, I hope you are doin' great! How high is the amount of calories that your Charge 2 seems to be tracking? 'Cause let me explain to you that your Fitbit uses your personal data like your height, weight and gender to give you an estimated of calories burned, because even if you are not working out , remember that your bod still burning calories to meet all of it's functions, so even when you are sleeping, your body needs to burn calories, so that is w as soon as you wake up you'll see them on your Charge 2. However if the amount seems to be be too high, review you demographics, maybe you need to adjust that data to get more accurate results. So please let me know!
Have a nice day, guys!
01-31-2018 04:26
01-31-2018 04:26
02-02-2018 08:35
02-02-2018 08:35
Thanks for getting back to me @Fee-Fee! As I mentioned, your Charge 2 should be tracking calories burned even if you are not wearing it. Of course that it'll be just an estimated specially if you are not working out. However, if it is not recording them at all, then I suggest you to try to restart it by following the instructions in this post.
07-19-2018 21:23
07-19-2018 21:23
Not to hijack the thread, but I'm also having the same issue. My charge 2 shows a heart rate even after I take it off and I haven't been wearing it for several minutes. What do I do about this? Is it just defective?
07-20-2018 04:03 - last edited on 09-10-2021 19:01 by LiliyaFitbit
Good morning. I contacted Fitbit and they are very good at customer service. They found mine defective by what I told them and they sent me a refurbished one. So far so good tho sometimes it shows a rate higher than my actual rate. Good luck 🍀
Sue
Sent from my iPhone
07-20-2018 10:24
07-20-2018 10:24
Hey @ShannonRawr, it is nice to see new faces around! Let's go ahead and confirm what is going on with your Charge 2, so please try the following:
a. Switch HR setting to off and sync.
b. Switch HR setting to Auto and sync.
c. Wait at least 60 seconds before checking heart rate again
@SueMomma622, thanks for the update! Sounds awesome that our Support team has sent you a Charge 2 as a replacement. They are simply the best! 😉
Keep me posted guys!
07-25-2018 11:01
07-25-2018 11:01
Hiya,
I tried these steps, I also reset the app, i installed all updates and it still shows a heart rate when i'm not wearing it. I now have to just turn the HR off when i'm not wearing it because it seems to just guess a heart rate.
It really makes me question the accuracy of the reading - it seems to be based on how fast it's moving (going up if I've got it in my backpack while walking around) and slowing down when it's just left still. Can you please advise? Is this a problem with my device or a problem with all Charge 2 devices?
Thanks,
Grace
07-25-2018 12:42
07-25-2018 12:42
Hey @Greddy, welcome aboard! I appreciate you have taken the time to try to fix this. Since your Charge 2 still tracking heart rate while you are not wearing it, I have escalated your case with our Support team so they can further assist you. So please keep an eye on your inbox. 😉
07-25-2018 14:22
07-25-2018 14:22
I'm having the same problem and have tried following the steps here with no luck. My Charge 2 consistently thinks I've worked out at peak effort when Im not wearing it (showering or swimming). What are my options here?
07-27-2018 06:05
07-27-2018 06:05
Hey @Shiggs11, it is great to see new faces around! I appreciate the time that you have taken to try to fix this issue. Since it persists, I have escalated your case to our Support team for further assistance, so please keep an eye on your inbox. 😉
07-31-2018 12:15
07-31-2018 12:15
Same for me on charge 2. 140 HR still reading after 10-15 minutes not wearing...
08-01-2018 05:29
08-01-2018 05:29
Hi @avrilathens, let me give you a warm welcome to the Community! If your Charge 2 is tracking heart rate while you aren't wearing it, I suggest you to try the following:
08-01-2018 06:58
08-01-2018 06:58
08-01-2018 07:28
08-01-2018 07:28
Thanks! I tried these recommendations a few times and they didn't solve the problem. The customer service team has sent me a replacement.
Thank you,
Steph
