High/peak heart rate monitoring incorrect
A picture says a thousand words, so here is 4000 words.
Run 1
Heart rate according to Fitbit:
Run 1, heart rate according to FitbitHeart rate according to chest strap:
Run 1, heart rate according to chest strap
Run 2
Run 3, heart rate according to FitbitHeart rate according to chest strap:
Run 2, heart rate according to chest strap
Has anyone else experienced this and/or know a solution?
Thanks
4 REPLIES 4
Welcome to Fitbit word where accurate HR is not a priority at all.
So, when you're doing exercises you should wear the trackert a little tighter and a little higher on the arm (meaning not on the "wrist bone" but slightly above).
That's what Fitbit says in the instructions and I assume it's to avoid fluctuations due to abrupt changes in the tracker position.
Are you doing that? Just to rule out the basic potential causes. 🙂
I did do that, but now I've done it cut-off-circulation-level tight and so since doing that it hasn't had the issue again. So maybe it's okay now.
And, as soon as I post this, the issue reoccurs. So, no, I take it back - Fitbit is still **ahem** at measuring heart rate.
