04-21-2019
21:31
11:08
04-21-2019
21:31
11:08
This morning my Fitbit was fine, but when I put it on charge I noticed white horizontal lines on my screen and my Fitbit not acting right at all. It won’t do any commands I’m telling it to do, it just does what it wants to. The screen moves on its own. I’ve tried many troubleshooting techniques and nothing has worked. It’s never been wet. I got it for Christmas so it’s not even that old.
08-28-2020 13:00
08-28-2020 13:00
I have this issue too. Ive tried everything that has been suggested and the lines are still there 😟
Best Answer08-28-2020 16:11
08-28-2020 16:11
Same issue, got it less than a year ago and worked great up until this last week. Have tried the suggested fixes and am hoping that someone has figured out a fix for this.
Thanks in advance!
Best Answer08-28-2020 16:35
08-28-2020 16:35
Hello,
I'm having the same issue with my charger 3 - black horizontal lines on my screen. I have tired resetting it and changing the clock face but the black lines are still there. I have had my fitbit for just under a year. Please let me know the easiest way to solute this problem.
Thanks!
Best Answer08-28-2020 19:56
08-28-2020 19:56
I purchased a charge 3 in Oct 2019. Horizontal lines started about 2 months ago. I have tried all the suggested fixes with no luck. Help!
Best Answer08-29-2020 21:09
08-29-2020 21:09
I’m having this issue now, and this is a replacement that I received in May or June. I don’t think my Fitbit is under warranty anymore, but let me tell you, this was my 2nd replacement since buying the Charge3 in July 2019. The first one stopped syncing in November. Fitbit replaced it. That replacement lasted until May or June, and it started getting lines. More and more lines each day, and then it just died. The screen stayed blank. Fitbit replaced that one. And now here I am, just a few months later, and the same issue as the last seems to be happening. I wondered if maybe my charger was culprit, since I’ve had it for all 3 of these trackers. Or maybe it’s a really common problem?! It’s really hard to believe that I would get 3 lemons. My charge2 lasted 2 years. No problems other than a cracked screen! It was still technically working when I traded it in for the charge3. But after these issues with charge3, I’ve determined that if I’m outside the warranty window, I’m going to try a different brand tracker.
Best Answer08-30-2020 00:09
08-30-2020 00:09
I am having the same trouble. Tried all the suggestions but nothing has worked.
Best Answer09-06-2020 16:42
09-06-2020 16:42
I am having the same issue with horizontal lines. I did the 8 second restart, the 15 second restart, and changed the clock face multiple times. My Fitbit is fully charged.
Best Answer09-06-2020 23:43
09-06-2020 23:43
09-07-2020 10:55
09-07-2020 10:55
I got offered a replacement because mine was only a few months old and it arrived today. Thing is Ive lost faith in it now so Ive bought a Garmin.
Best Answer09-27-2020 20:48
09-27-2020 20:48
I am having the same issue with horizontal lines. It's fully charged. Tried the 8 second restart, the 15 second restart, and changed the clock face multiple times. The charge 3 is fading. It still keeps data and talks with my phone. Lost my receipt!
Best Answer09-28-2020 00:17 - last edited on 09-28-2020 20:18 by LiliyaFitbit
Hi
Thank you for coming back to me. I had a problem with my previous Fitbit
Charge 3, which was still under guarantee. It had the horizontal lines and
one of FITBIT consultants assisted me and finally the watch was replaced
about 1.5 years ago. I cannot recall the exact date.
The new watch has the same problem now. Horizontal lines on the face. I
have changed the face, I also restarted the watch and none of the 2
methods solved the problem, The face is now totally blank, although it
still syncs to the app.
I don't know if you have an alternative method to fix the screen, but now
the watch is useless to me.
It will be great if you have a method to fix it as I am aware that it is
not under guarantee anymore..
Kind regards
Best Answer09-28-2020 03:32
09-28-2020 03:32
Best Answer01-05-2021 01:15
01-05-2021 01:15
I have the same issue.also I have done all the restarts and upgraded the app
it is also not picking up my heart rate
Best Answer02-17-2021 08:07
02-17-2021 08:07
Hi there, I’m having the same problem, and the horizontal lines are increasing daily, I now can’t see the time or date.
I read about and tried to long reset, no change, and my Fitbit is fully charged. It still syncs, has had no bumps or damage. It is just over a year old, Xmas pressie last year-but previous trackers have lasted longer. Is there any hope?
Best Answer02-17-2021 08:23
02-17-2021 08:23
Best Answer02-17-2021 09:03
02-17-2021 09:03
Best Answer02-17-2021 09:55
02-17-2021 09:55
I have had my fitbit since 2019. Had 2 replacements to fix the brightness issue (too bright at not; can't see display in sunlight). That never got fixed and now I am also getting the lines on the display. I have done all the recommendations on this Thread and nothing works.
Thanks
Best Answer02-17-2021 10:36
02-17-2021 10:36
Best Answer02-17-2021 10:48
02-17-2021 10:48
Best Answer02-17-2021 11:09
02-17-2021 11:09
