Hourly walking target - Guys please help me change it
I approached FitBit direct on this but they told me the FitBit community would need to support it for it to happen.
Following cancer (clear now) my oncologist recommended I walk 5 miles a day and do that spread through the day. My beef is that although FitBit allows you to set yourself a numbers of hours target it is only through hours that are continuous. I'm pretty sure most people have the same issue that I do - I can do my 12 hours in 24 target but rarely as a continuous block. So could FitBit offer two options - 1) Every hour between X and Y (as it is today) AND 2) Z hours between X and Y.
2 REPLIES 2
Sorry this area is for help with hardware issues, for suggestion we have another board.
A quick search of the feature request board brings up this suggestion to add votes to.
Allow non-consecutive hours in the Hourly Movement...
As you can see I don’t use the boards that often. I raised the query direct whilst having an issue with my FitBit and was directed ‘to the community board’ without actual directions. Thank you for pointing me to the right place. Just a bit disappointed that FitBit aren’t considering it.
