07-28-2019
01:00
19:58
07-28-2019
01:00
19:58
Hi Guys
Please i need to know how Fit Bit or (charge HR) calculate the calories .
Depending on what ??
i will give an example:
yesterday i did workout for 66 minutes
result was:
heart average : 104 bpm
calories burned : 350
fat burned 100%
while>>
2 days before; i did workout for 111 minutes
result was:
heart average : 101 bpm
calories burned : 542
fat burned 97%
another day:
I went for walk for 75 minutes
result was:
heart average : 133 bpm
calories burned : 825
fat burned 46%
there is very big difference in all the parameters .. so can you please explain how it works ?? how Fit Bit calculate all these issues ?? depending on what ??
Thanks a lot
Mayan
07-28-2019 07:13
07-28-2019 07:13
See How does my Fitbit device calculate calories burned?
For a person of given age, sex, height, weight, the biggest factor in calorie burn rate is intensity, as measure by heart rate.
Your 2nd workout with the lowest avg heart rate, you were burning 4.9 calories per minute.
The first workout with slightly higher heart rate, 5.3 calories per minute.
The third workout, with avg heart rate much higher, you burned 11 calories per minute.
As you can see, higher heart rate gives higher calorie burn per minute.
And, of course, the longer you exercise, the total calories increase.
The "fat burned" %, I expect you are actually looking at percent of time in fat-burning zone, which is just a certain range of heart rates.
See What are heart-rate zones?
