How can I add 'workout' to my list of exercises on Charge 3?
I would like to replace the settings for elliptical,  bike,  and swim with other exercises such as interval workout and workout in my charge 3. Is that possible? If so,  how?
3 REPLIES 3
@mpipkin   This Help article has a section with the instructions to customize your Exercise Shortcut list.  If the "+ Exercise Shortcut" is greyed out, it means that your shortcut list is full.  You need to use the Edit option to remove something to make room for what you want to add.
Laurie | Maryland
Thank you so much for your response. I will give this a try.
Marilyn
@mpipkin It's great to see you around! @LZeeW Thank you for your great input and it's nice to see you around!
@mpipkin I was able to see that you received information about your inquiry on a post above. If it was the answer you were looking for, I recommend marking the answer given as the best answer, by doing this, other users with the same inquiry will be able to find a faster response.
See you around.
Wilson M. | Community Moderator, Fitbit.
